Reyft Posted January 18, 2015 Share Posted January 18, 2015 (edited) What could happens if LSD (Slip) fail when you drive under pressure.!! Edited January 19, 2015 by Reyft (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest mojje Posted January 19, 2015 Share Posted January 19, 2015 What could happens if LSD (Slip) fail when you drive under pressure.!! if its a torsen lsd like the one fitted in oem tt, then you have a big prob, if you go full on 3 and 4 gear full torque and the torsen goes, then one of your wheel gonna get all torque and that result in a 1 wheel spin/power and 100% sure accident, if you are luck maybe you just hit the road wall/wire, or if you are unlucky you will front with an other car. A trd or aftermarket lsd like i see it is a 1st thing safeforyourselfupgradethingtodo,then that its a damn nice upgrade you get in the kit. //M Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted January 19, 2015 Share Posted January 19, 2015 With 600bhp you're not going to break anything on the big diff... If it does Fail various things could happen depending on how it fails... one or both wheels could lock, one could get more power. Who knows. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 19, 2015 Share Posted January 19, 2015 Should be ok unless you have a facelift with the small diff, donut normally fails if the wheels lock up. thats whats happened every time ive broke a diff. trouble is the prop can then swing about, damaged the floor and took out the handbrake cables on me the last time. Quote Link to comment Share on other sites More sharing options...
