ballsdeep Posted January 18, 2015 Share Posted January 18, 2015 Does the exhaust side breather fitting rotate? I bought a whifbitz stage 1 oil catch tank and I'd like the hose to run to the back of the engine, but it's currently facing forward and seems very tight! Fitting just above the ht leads. Link to comment Share on other sites More sharing options...
MattP Posted January 18, 2015 Share Posted January 18, 2015 I don't think it does move tbh mate I'm sure people remove the cover and baffle and weld new attachments on if I remember correctly.. Link to comment Share on other sites More sharing options...
ballsdeep Posted January 18, 2015 Author Share Posted January 18, 2015 that's not an option for me at this time! There must be another solution? Link to comment Share on other sites More sharing options...
MattP Posted January 18, 2015 Share Posted January 18, 2015 that's not an option for me at this time! There must be another solution? I'm a bit out of my depth as I'm still TT so my knowledge is limited as to what is the normal for you single converts Link to comment Share on other sites More sharing options...
ballsdeep Posted January 18, 2015 Author Share Posted January 18, 2015 Found one or two references to show it in a different position, so il try abit harder maybe it's the paint deceiving me? Hopefully it won't break? Link to comment Share on other sites More sharing options...
Lee P Posted January 18, 2015 Share Posted January 18, 2015 They do move but sometimes they are tight, be careful you don't crush it while trying Link to comment Share on other sites More sharing options...
ballsdeep Posted January 18, 2015 Author Share Posted January 18, 2015 Thanks for confirming that! Link to comment Share on other sites More sharing options...
MattP Posted January 18, 2015 Share Posted January 18, 2015 Thanks for confirming that! Told you I'm S*** Link to comment Share on other sites More sharing options...
Ian C Posted January 18, 2015 Share Posted January 18, 2015 Put something as near to the inner diameter as possible into it and use that to lever it around. A screwdriver or a socket extension bar, for example. Don't try pushing it from the outside or it'll deform Link to comment Share on other sites More sharing options...
