jsnlvxr Posted January 17, 2015 Share Posted January 17, 2015 would it be much of a issue to fit 11j rear et8 and 9.5j front et10 in 18s? ive already had the arches rolled for current wheels.thanks! Link to comment Share on other sites More sharing options...
kirky_123 Posted January 17, 2015 Share Posted January 17, 2015 I believe it is too much, wider wheels require higher offsets, you would more likely need them widths to be around +40 upwards Link to comment Share on other sites More sharing options...
abtin90 Posted January 17, 2015 Share Posted January 17, 2015 No chance of them fitting under stock rolled arches. You'll need wide arches for those wheels. Link to comment Share on other sites More sharing options...
Ric Posted January 17, 2015 Share Posted January 17, 2015 not a chance as said above. They will stick out around 35mm past the arch, 3.5cm, they are 100% wide arch wheels. Link to comment Share on other sites More sharing options...
jsnlvxr Posted January 17, 2015 Author Share Posted January 17, 2015 ok cool thanks guys. i have though about running a wide arch so il bear them in mind. Link to comment Share on other sites More sharing options...
