Please help 2jz not firing
paul21uk
Guys as above
I have done a rebuild 1.5jz as I done a bearing in another engine full loom was removed from the engine bay everything put back in but I'm not getting any start, the car turns over but that's it..
Coil packs seem to be getting power but are intermittent readings ie 1st is 12v 2nd is lower and as is the third
I heard a pop noise coming from the drivers side under the bonnet which makes me think I done a fuse and something wasn't earthed correctly can anybody please shed some light on this as I have checked all fuses replaced most relays to which I think it could be thanks
That's what I thought but I was a big dumb ass and struck it with out any of the main earths on and I heard quite a load pop from say the servo area it's now all seems to be earthed but still nothing which is making me think of somewhere else.. However as my loom was all brittle I am re looming the engine bay and see if that helps
