JackyBoi Posted January 24, 2016 Author Share Posted January 24, 2016 The cylinder head flange is separated with a gap to allow for expansion, the flange on the one you pictured is one piece. Ah I think I see, the slot on the header flange right in the middle of the 6 runners? Link to comment Share on other sites More sharing options...
Hemanhead Posted January 24, 2016 Share Posted January 24, 2016 As you are changing your Turbo setup due to selecting the wrong things the first time around, why would you want to experiment a second time round? Order whifbitz or SRD manifold and be done with it. It's really not the most expensive part the conversion mate. Link to comment Share on other sites More sharing options...
JackyBoi Posted January 24, 2016 Author Share Posted January 24, 2016 As you are changing your Turbo setup due to selecting the wrong things the first time around, why would you want to experiment a second time round? Order whifbitz or SRD manifold and be done with it. It's really not the most expensive part the conversion mate. Because it's a lot more fun to experiment with different kits, different brands and different setups than it is to just buy very expensive stuff that fits straight away Link to comment Share on other sites More sharing options...
j_jza80 Posted January 24, 2016 Share Posted January 24, 2016 If you are going to use one of those manifolds, make sure you brace the turbo, and get a decent flexi section welded into the exhaust just after the downpipe. That will do more for the manifold than welding it. Link to comment Share on other sites More sharing options...
JackyBoi Posted January 24, 2016 Author Share Posted January 24, 2016 If you are going to use one of those manifolds, make sure you brace the turbo, and get a decent flexi section welded into the exhaust just after the downpipe. That will do more for the manifold than welding it. I did say it would be braced we're gonna brace the absolute **** out of it to try and prevent any cracks. At the end of the day, if it doesn't work, I can chuck it and spend money on a proper manifold! Link to comment Share on other sites More sharing options...
j_jza80 Posted January 24, 2016 Share Posted January 24, 2016 Im looking into this myself, as even with a hks manifold i think leaving the turbo unsupported will cause issues. Im thinking of making a bracket that attaches to the 2 rearmost but 1 sparkplug cover threads on both cam covers, and using an arm to attach it to the turbo. Link to comment Share on other sites More sharing options...
JackyBoi Posted January 24, 2016 Author Share Posted January 24, 2016 Im looking into this myself, as even with a hks manifold i think leaving the turbo unsupported will cause issues. Im thinking of making a bracket that attaches to the 2 rearmost but 1 sparkplug cover threads on both cam covers, and using an arm to attach it to the turbo. It's worth it mate. I didn't bother bracing these twins but I should have - any kit I put on in the future will definitely be braced! Link to comment Share on other sites More sharing options...
JackyBoi Posted January 24, 2016 Author Share Posted January 24, 2016 Managed to squeeze a couple hours in today after work. Got the front turbo off which was a complete pain due to one bolt being in an inaccessible place, many many swears and tears later it was out. This bolt is gonna be fun - left it for next time. Picture doesn't really show how impossibly awkward it is to get to, especially as there's a nut as well Anyone know of some tools that are great for getting in those kind of places? Link to comment Share on other sites More sharing options...
Nic Posted January 24, 2016 Share Posted January 24, 2016 Im looking into this myself, as even with a hks manifold i think leaving the turbo unsupported will cause issues. Im thinking of making a bracket that attaches to the 2 rearmost but 1 sparkplug cover threads on both cam covers, and using an arm to attach it to the turbo. Might be worth talking to CW, see this post http://www.mkivsupra.net/vbb/showthread.php?90717-My-Single-Kit&p=1150855&viewfull=1#post1150855 Link to comment Share on other sites More sharing options...
j_jza80 Posted January 24, 2016 Share Posted January 24, 2016 Looks pretty good. Link to comment Share on other sites More sharing options...
JackyBoi Posted January 24, 2016 Author Share Posted January 24, 2016 http://www.gurneyflap.com/Resources/DSC06001.jpg Looks pretty good. Is it the bracing you're looking at? I'm thinking about polished rods that connect the header flange to the turbo flange, and something else to brace the actual turbo to the engine bay, with some measures to allow expansion Link to comment Share on other sites More sharing options...
j_jza80 Posted January 24, 2016 Share Posted January 24, 2016 As Nick said, when you look at motosport type braces, they seem to be rose jointed. Rose joints aren't expensive either. Welding rods between the flanges *may* actually cause cracking. Link to comment Share on other sites More sharing options...
JackyBoi Posted January 25, 2016 Author Share Posted January 25, 2016 As Nick said, when you look at motosport type braces, they seem to be rose jointed. Rose joints aren't expensive either. Welding rods between the flanges *may* actually cause cracking. I see, one of these? Link to comment Share on other sites More sharing options...
j_jza80 Posted January 25, 2016 Share Posted January 25, 2016 Yeah i think ideally youd need a couple. Im going to be doing this as soon as i get my supra back. Link to comment Share on other sites More sharing options...
JackyBoi Posted January 26, 2016 Author Share Posted January 26, 2016 Got a load more work done today! Manifolds out and ready to all be cleaned up just a wastegate, downpipe and some AN fittings to be taken off before cleaning up the kit and listing it for sale: Also had the pleasure of changing the exhaust system on a R32 today Link to comment Share on other sites More sharing options...
JackyBoi Posted February 2, 2016 Author Share Posted February 2, 2016 So this arrived today £138 special delivery from Shanghai as mentioned, plan with this is to machine flatten all flanges, relocate wastegate pipes, blast any slag out from inside the tubes, and brace the hell out of the turbo. We've decided to use a bracing method that will suspend the turbo from above, essentially removing 80% of the weight from pushing on the manifold, increasing the potential for cracks. Will test fit by the end of this week hopefully. It always gets exciting when parts start turning up Was also slaving over my manifolds the past two days to get them looking as close to new as possible. Not too bad considering how old they are + how young I am! Ordering the S366 soon as well, including some new tasty parts for the ol' gal Link to comment Share on other sites More sharing options...
Chris Bailey Posted February 2, 2016 Share Posted February 2, 2016 How comes you opting for a S366 now? Thought you was sold on the 6466? Link to comment Share on other sites More sharing options...
JackyBoi Posted February 3, 2016 Author Share Posted February 3, 2016 How comes you opting for a S366 now? Thought you was sold on the 6466? Purely to save a bit of money for other jobs; 6266/6466 dbb is £1500 brand new, can get an S366 for £650 brand new and they're still a great turbo so why not Link to comment Share on other sites More sharing options...
np89 Posted February 3, 2016 Share Posted February 3, 2016 Purely to save a bit of money for other jobs; 6266/6466 dbb is £1500 brand new, can get an S366 for £650 brand new and they're still a great turbo so why not Are you going for the boostlabs variant with the billet wheel. What exhaust housing are you going for? Link to comment Share on other sites More sharing options...
Ric Posted February 3, 2016 Share Posted February 3, 2016 Going from a quality piece of kit to cheap Chinese parts.. why? Link to comment Share on other sites More sharing options...
np89 Posted February 3, 2016 Share Posted February 3, 2016 BW S366 or the Boostlabs variant are hardly cheap chinese parts are they? - They are manufactured in the US for a start and there are no horror stories with them that I am aware of. What makes you say that Ric? - genuinely interested Link to comment Share on other sites More sharing options...
Mike2JZ Posted February 3, 2016 Share Posted February 3, 2016 BW S366 or the Boostlabs variant are hardly cheap chinese parts are they? - They are manufactured in the US for a start and there are no horror stories with them that I am aware of. What makes you say that Ric? - genuinely interested Think he is referring to the chinese manifold not the turbo Link to comment Share on other sites More sharing options...
np89 Posted February 3, 2016 Share Posted February 3, 2016 Think he is referring to the chinese manifold not the turbo Oh ok fair enough my mistake! Link to comment Share on other sites More sharing options...
JackyBoi Posted February 3, 2016 Author Share Posted February 3, 2016 Going from a quality piece of kit to cheap Chinese parts.. why? *part, as it's only one Chinese part, and why not? No one on here (that I know of at least) has a cheap and cheerful Chinese manifold and I want to see if it will actually work or not for a prolonged period of time - if it does then happy days; I've just saved about a grand. If not, then it can be binned and a proper manifold will be purchased Link to comment Share on other sites More sharing options...
baldy Posted February 3, 2016 Share Posted February 3, 2016 (edited) *part, as it's only one Chinese part, and why not? No one on here (that I know of at least) has a cheap and cheerful Chinese manifold and I want to see if it will actually work or not for a prolonged period of time - if it does then happy days; I've just saved about a grand. If not, then it can be binned and a proper manifold will be purchased nice to see your not just following everyone else. hopefully you'll prove the haters wrong and it works well Edited February 3, 2016 by baldy (see edit history) Link to comment Share on other sites More sharing options...
