Supraleeturbo Posted January 9, 2015 Share Posted January 9, 2015 Hi guys does anyone know where or who sells these and is there and uk site With uk prices Cheers Quote Link to comment Share on other sites More sharing options...
mattdavies Posted January 9, 2015 Share Posted January 9, 2015 I believe you can only buy them direct. Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted January 9, 2015 Share Posted January 9, 2015 http://www.ccwheel.com/ Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 9, 2015 Share Posted January 9, 2015 Beware, a customer bought some of these at vast expense and the things came with the wrong sized spigot holes and CCW told him they would need adaptor rings. This is NOT something you should accept or expect with expensive rims, the centres should be machined to be a direct and perfect fit on the recipient vehicle's hub snouts. The might have looked beautiful, and they did, but basically they didn't fit... Quote Link to comment Share on other sites More sharing options...
Supraleeturbo Posted January 9, 2015 Author Share Posted January 9, 2015 Beware, a customer bought some of these at vast expense and the things came with the wrong sized spigot holes and CCW told him they would need adaptor rings. This is NOT something you should accept or expect with expensive rims, the centres should be machined to be a direct and perfect fit on the recipient vehicle's hub snouts. The might have looked beautiful, and they did, but basically they didn't fit... gutted thanks for the advice Quote Link to comment Share on other sites More sharing options...
Alex Posted January 9, 2015 Share Posted January 9, 2015 @CW - whist you're right, it seems impossible to get mass manufacturers to do the correct spigots or in fact supply suitable rings to go with them. And whilst I agree it's not ideal in ultimate terms, Digsy said in a post the other day that ultimately beyond locating the wheel plum straight on a road car they are not an absolute requirement. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 9, 2015 Share Posted January 9, 2015 I would disagree, the hammering over ridges, potholes, cat's eyes, whatever needs to be taken on the hub snout, that's what it's there for, not by the wheel studs or bolts, or by some narrow bit of plastic or alloy shoved into the centre hole. Show me one production car that has wheels with a spigot hole bigger than the hub snout, or that uses adaptor rings. Image Wheels will do proper centres, maybe CCW will, I don't know, but you need to clarify it in writing before ordering. IMO. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted January 9, 2015 Share Posted January 9, 2015 I ordered mine directly from CCW in the states. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 9, 2015 Share Posted January 9, 2015 If it's for your supra then you shouldn't need to worry about spigot bore/sizings. CCW know exactly what they need to provide supra-wise. (Still worth confirming it though obviously) My LM20's came with the correct supra-specific counter-bore to go straight onto the hub nose. Quote Link to comment Share on other sites More sharing options...
Mugello Posted January 9, 2015 Share Posted January 9, 2015 If it's for your supra then you shouldn't need to worry about spigot bore/sizings. CCW know exactly what they need to provide supra-wise. (Still worth confirming it though obviously) My LM20's came with the correct supra-specific counter-bore to go straight onto the hub nose. Agreed with James here. I ordered my CCW's for my build (some point last year) and they were very helpful. Of course always check the final invoice before you pay the fee. The invoice will have all the wheel specs on it etc.... Im over the moon with my CCW's. I would reccommend them to anyone, deal with them direct. Check my thread Quote Link to comment Share on other sites More sharing options...
Guest mojje Posted January 10, 2015 Share Posted January 10, 2015 i ordered mine form ccw direct, np at all i said maximum supra fitment and i recived it as well there is some ccw for sale in sweden any particular models you fancy, i can look for it in sweden for you, its used rims but most are in super shape. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 10, 2015 Share Posted January 10, 2015 I knew spigot rings weren't ideal, bit I didn't think they were that bad? Would they be better if they were billet, or even Ti? Was considering buying some of the OEM Rays forged wheels from a 350Z for my Supra, as they're a well made wheel, very light, well priced, and replacements are readily available. Iooks like I'll have to resume my search for some well priced BBS LMs instead Quote Link to comment Share on other sites More sharing options...
Nic Posted January 10, 2015 Share Posted January 10, 2015 Recent post by Digsy on the subject of spigot rings which I found interesting. http://www.mkivsupra.net/vbb/showthread.php?316200-plastic-or-metal-spigot-rings&p=3962250&viewfull=1#post3962250 Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 10, 2015 Share Posted January 10, 2015 (edited) The centre cap on them pulls though from the back and also doubles up as a spigot ring, if they have given him the wrong centre caps they shouldn't be an issue to change to get the correct 60.1. they are awesome wheels. Edited January 10, 2015 by JamieP (see edit history) Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 10, 2015 Share Posted January 10, 2015 The centre cap on them pulls though from the back and also doubles up as a spigot ring, if they have given him the wrong centre caps they shouldn't be an issue to change to get the correct 60.1. they are awesome wheels. Weird! Is that a classics thing? Perhaps to make mass manufacturing them easier. My LM20 centre caps fit conventionally, and the wheel has the correct counter bore. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 10, 2015 Share Posted January 10, 2015 Must be a classic thing if your LM's are different. Quote Link to comment Share on other sites More sharing options...
James Posted January 10, 2015 Share Posted January 10, 2015 Yep with a friend of mine having LM20s and having the Classics myself - they are definitely different. I had/have absolutely no issues with my CCWs. Best wheels I've ever had and they fit great. Being able to get a 285 up front and a 315 on the rear is great Quote Link to comment Share on other sites More sharing options...
Supraleeturbo Posted January 10, 2015 Author Share Posted January 10, 2015 Other than an arch roll/cut do you have to do anything else to run 11s at the rear Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 10, 2015 Share Posted January 10, 2015 Other than an arch roll/cut do you have to do anything else to run 11s at the rear 11.5's Mine touch the inner arches as well, I need to heat them up and move them back with a mallet or something. I guess it would depend on the tyre though. Quote Link to comment Share on other sites More sharing options...
Mugello Posted January 10, 2015 Share Posted January 10, 2015 The K57's are conventionally in terms of centre caps also Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 11, 2015 Share Posted January 11, 2015 11.5's Mine touch the inner arches as well, I need to heat them up and move them back with a mallet or something. I guess it would depend on the tyre though. Mine don't, maybe your LM's are a different offset. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 11, 2015 Share Posted January 11, 2015 Mine don't, maybe your LM's are a different offset. I think it's geometry.. they only just touch and my car has a tad too much negative on the back at the moment. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 11, 2015 Share Posted January 11, 2015 Love the SP16's http://www.ccwheel.com/wheels-display-hybrid-v2.php?view=SP16 http://www.ccwheel.com/img/wheels-display-hybrid/wheels/SP16/gallery/wheels/03.jpg Quote Link to comment Share on other sites More sharing options...
