UK Spec Automatic Transmission
np89
Hey guys, just noticed on TOYODIY, while lookign something up for someone else, The UK Spec Autobox, is different from the J-Spec Autobox
UK - 35000-1B330
J Spec - 35000-1B310
I know that the general consensus is that the Auto Transmission is only good for about 550BHP, i.e about 500Lbs/ft torque (gearbox heat killer), my question then is, could it be possible that the UK Spec box is superior? Does anyone know how they differ? Can they handle more perhaps?
Transmission gurus Go!!
I believe the electrical connectors are different too as when I bought a built box before none of the connectors matched up, they said it's because the box was for a jspec car as I never stated my car was uk spec when ordering. Could be wrong though.
The gearbox code numbers are a mystery that I've yet to unravel?
I'm reasonably sure that the boxes are the same spec, but are wired differently because the ECU's are slightly different.
The Aristo version has additional oil plumbing but I have not yet had my hands on one to play with.
You would need to get the Aisin Warner parts book and spend hours looking at valve body springs, clutch packs and brake bands, blah blah, to be sure, but I would highly doubt the torque handling of a UK spec auto box is any greater than a Jap spec. In my limited experience of people putting more torque through MKIV auto boxes, it's the lack of torque unloading during shifts that kill them more than sheer torque. the stock ecu goes to some lengths to reduce torque during and just after gear changes occur. Most aftermarket ones do not do this and the sudden shock loadings seem to kill the `boxes. Got two dead TT auto boxes here nowe, both off cars with aftermarkey ecus, single turbos and otherwise excellent maps, but WITHOUT torque limiting on gear changes. If I had the time and inclination I should strip them and see what's failed. but i suspect sprag clutches. NOT that I am an auto box guru...
Piggy back ecu is not such a bad way to go then after all.
I'll just leave the link here regarding what Transmission was used in what model :)
http://www.supra-forum.com/articles/general/transmissions/
There have been some conversions from the JSpec transmission to the EU one because of strength differences but i honestly don't know how much they differ.
I aggree that the killer for both boxes will be the gear changes without Torque reduction.
Well the writer doesn't know the difference between longer and shorter ratios :) ...
In my experience, half the automotive forum world doesn't understand higher/longer vs lower/shorter. It's always a good topic for an argument, though. :)
I was taught "higher number = lower/shorter gear".
Obvious when you consider that 1st gear (2.804:1) is lower than 4th gear (0.753:1).
