Rear Subframe bushes
Jellybean
So I am getting all new suspension , my mechanic said to get Solid Rear Subframe mounts but I am thinking either OEM Rear Subframe bushes or
as a compromise I can get Stiffer TRD Rear Subframe bushes
He said it will stop the subframe moving around, it is a road car not track.
Anybody have any experience with OEM setup and Solid Rear Subframe mounts?
Will it transfer unnecessary vibrations through the OEM bushes , Vibrations they are not designed to take? increase unnecessary wear?
Front
48630-19025 ARM ASSY, FRONT SUSPENSION, UPPER LH
48610-19025 ARM ASSY, FRONT SUSPENSION UPPER, RH
48068-14080 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 RH
48069-14080 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 LH
45460-19235 Track Rod RH
45470-19065 Track Rod LH
48820-24010 LINK ASSY, FRONT STABILIZER, LH
48820-24010 LINK ASSY, FRONT STABILIZER, RH
48815-14080 BUSH, FRONT STABILIZER BAR, NO.1
Rear
48770-19025 ARM ASSY, UPPER CONTROL, REAR RH
48790-19025 ARM ASSY, UPPER CONTROL, REAR LH
48710-14110 ARM ASSY, REAR SUSPENSION, NO.1 RH
48710-14110 ARM ASSY, REAR SUSPENSION, NO.1 LH
8725-14070 BUSH, REAR AXLE CARRIER, LH
48725-14070 BUSH, REAR AXLE CARRIER, RH
48818-14050 BUSH, STABILIZER, REAR
48830-14050 LINK ASSY, REAR STABILIZER, RH
48840-14030 LINK ASSY, REAR STABILIZER, LH
JZA80 Rear Diff/Differential Mounting Bush Kit SuperPro
Diff Cushion for 1993-98 Toyota Supra TT Part # 41651-14020
Diff Cushion for 1993-98 Toyota Supra TT Part # 41651-14010
