Bluudy Posted January 1, 2015 Share Posted January 1, 2015 Hey everyone. Merry new year! Im after some tips. I have a na auto. I am wanting to remove both engine (for degreesing and painting) and gearbox so i can swap to manual. is it best to remove as one? Or gearbox seperate. Anything thing thats awkward? Etc. I have the toyota manual to and i have read it. Just of there was anything else! Thanks Bluudy Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 1, 2015 Share Posted January 1, 2015 Separately, the two combined need a really hefty iron man, and probably the car on ramps to let the box tip low enough. I always split them to remove them myself, unless I leave the engine on the X/member and send the car up on he ramp leaving the lot on the floor. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted January 1, 2015 Share Posted January 1, 2015 I took the whole lot out in one go on my driveway; TT and 6 speed. I managed to get the car about 60cm in the air on stands, unbolted everything apart from the engine mounts and gearbox brace, supported the lot with a jack under the box and the crane taking the weight of the block, then undid the brace and mounts and slowed pulled the lot out. You need a decent, flat and fairly smooth bit of ground (so when you move the crane it doesn't get stuck!) and be patient with it. Easing the box out while bolted to the engine involved a bit of wiggling and you need to be able to tilt the whole lot on the crane; I actually used a seat belt to lift it all! Chain doesn't work well unless you have a balance bar. I also just disconnected the engine harness inside the car and pulled it our with the block, then disconnected it while on the stand. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 1, 2015 Share Posted January 1, 2015 One more for taking everything out together. Engine mounts can be tricky, Ive trashed a pair before, other than that take your time and triple check everything. An engine hoist is a great tool for testing the tensile strength of forgotten pipes and looms Quote Link to comment Share on other sites More sharing options...
straightsix Posted January 1, 2015 Share Posted January 1, 2015 Easy to remove in one lump if you have an engine hoist. take the bonnet off though (obviously!) Quote Link to comment Share on other sites More sharing options...
Bluudy Posted January 1, 2015 Author Share Posted January 1, 2015 Ok thanks peeps. Ive built myself a garage to work in so i have the room to use a crane. Whats the combined weight of engine and box? Less than half a tonne? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 1, 2015 Share Posted January 1, 2015 Less than half a ton yes, exactly figure, not sure. Quote Link to comment Share on other sites More sharing options...
trebor69 Posted January 1, 2015 Share Posted January 1, 2015 Bonnet off, front end up with ramps under wishbone mounts then both out together. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted January 2, 2015 Share Posted January 2, 2015 Half a ton load capacity for the crane will be fine. By block is on a 450kg engine stand too and it's happy as Larry! Quote Link to comment Share on other sites More sharing options...
Bluudy Posted January 3, 2015 Author Share Posted January 3, 2015 Ok brill thanks guys! Quote Link to comment Share on other sites More sharing options...
Guest bua Posted January 7, 2015 Share Posted January 7, 2015 I took the whole lot out in one go on my driveway; TT and 6 speed. I managed to get the car about 60cm in the air on stands, unbolted everything apart from the engine mounts and gearbox brace, supported the lot with a jack under the box and the crane taking the weight of the block, then undid the brace and mounts and slowed pulled the lot out. You need a decent, flat and fairly smooth bit of ground (so when you move the crane it doesn't get stuck!) and be patient with it. Easing the box out while bolted to the engine involved a bit of wiggling and you need to be able to tilt the whole lot on the crane; I actually used a seat belt to lift it all! Chain doesn't work well unless you have a balance bar. I also just disconnected the engine harness inside the car and pulled it our with the block, then disconnected it while on the stand. Will take mine out this weekend as well, have shitty surface for the crane tho... was hoping to do it on my own, but sounds like i may need some help, in case it stuck.... Quote Link to comment Share on other sites More sharing options...
Bluudy Posted January 7, 2015 Author Share Posted January 7, 2015 Heres my progress so far, now starting on the engine Quote Link to comment Share on other sites More sharing options...
