simbasupra Posted December 31, 2014 Share Posted December 31, 2014 Hi guys, just trying to wire up my twin kenlowe fans. However just want to make sure I do it correctly as instructions aren't supra specific. Where do people mount the optional electronic fan controller? Also what wires are used for 12v ignition supply and a/c override? Should I use the negative battery terminal or chassis for the earth lead? Finally the fans both have a earth lead where do people normally wire these too? Link to comment Share on other sites More sharing options...
Lee P Posted December 31, 2014 Share Posted December 31, 2014 Mount the controller some where safe where it wont get knocked or damaged. You don't need to use the AC override 12v power direct to battery or if you want it neater run it into the fuse box and bolt it to the main power there 12v ignition you can pick up in the fuse box as there are quite a few switched supplies in there Earths for the fans on the chassis, there is a bolt behind the battery on the chassis leg, use that You can also mount the controller on the side of the chassis leg You will need to trim the battery tray slighty around the fans Link to comment Share on other sites More sharing options...
Philly_1 Lex Posted December 31, 2014 Share Posted December 31, 2014 Best fans for the mkiv imho. I loved them. Clean up the bay so much. Link to comment Share on other sites More sharing options...
