Ian. Posted January 2, 2015 Author Share Posted January 2, 2015 I'd be surprised that a well respected firm like Abbey Motorsport would recommend using a set of normal 350z coilovers on a custom project like this. Having seen their impressive work with Skylines, they don't appear to be the sort of company that cuts corners. Probably because they aren't required and a set of coilovers are fine. Ofcourse your the expert when it comes to swapping a 2jz into a 350z.......... If you could assist throughout the rest of the build it would be a huge help. I'll send you my build plan by pm & you can alter as you see fit Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 2, 2015 Share Posted January 2, 2015 I don't even know where to start, so I won't. Best of luck, and I'd be happy to help with any queries you may have Quote Link to comment Share on other sites More sharing options...
Ian. Posted January 9, 2015 Author Share Posted January 9, 2015 Car is starting to come along now These are ready to go in Engine mount kit is sat in customs right now waiting for release coilovers, roll bars and gauges are on the way all thats left to buy is radiator race tech dash exhaust polybushes intercooler piping fuel system Quote Link to comment Share on other sites More sharing options...
Ian. Posted February 2, 2015 Author Share Posted February 2, 2015 350Z-2JZ subframe, engine mounts and brackets turned up went to offer it up to the car and we all realised we had overlooked something - its for a LHD car so rather than mess about with moving the mounting points around we just did this to the existing subframe its off to get powdercoated blue tomorrow Had a few things come through this week for my build Had a few deliveries today :teeth: Koyo 54mm radiator Cusco Street Zero Coilovers, Front & Rear ARBs Defi control unit, Boost, Oil pressure & Oil temp gauges GReddy clear 2JZ engine cover Race tech dash should be here next week. Need to order new suspension arms, Brides & a BBK in the next few days also. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted February 15, 2015 Share Posted February 15, 2015 nice project. how much was the 350z gearbox to 2jz conversion bud? if you dont mind me asking Quote Link to comment Share on other sites More sharing options...
Ian. Posted February 15, 2015 Author Share Posted February 15, 2015 The gearbox convertor was £1300 and that includes adaptor plate, clutch and flywheel Quote Link to comment Share on other sites More sharing options...
listy Posted February 15, 2015 Share Posted February 15, 2015 The gearbox convertor was £1300 and that includes adaptor plate, clutch and flywheel That seems a good price. May have to find out how much a Z box to supra mount would be. Could be a reasonable alternative now R154 conversions are going up in price. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted February 18, 2015 Share Posted February 18, 2015 looking forward to seeing this Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted February 18, 2015 Share Posted February 18, 2015 Saw a 1JZ 350Z yesterday with an upgraded single turbo, looked a bit of an animal! Same colour as this too. Quote Link to comment Share on other sites More sharing options...
Ian. Posted March 21, 2015 Author Share Posted March 21, 2015 Starting to see some progress at last. Engine should be back from machine shop in the next 2 weeks and we should start to see even more progress then Got a few more parts through aswell 370Z brake upgrade GT Spec braces Cusco camber arms, rear railing rod & adjustable toe control rods 2JZ-350Z gearbox conversion kit Race tech Dash 2 Chase bays 2JZ 350Z power steering tank Agency Power exhaust ARC intercooler should be here soon Subframe is back from powder coaters Applied some heatwrap to the turboside of the engine We are just waiting now for the engine to return from machine shop. The wiring loom & clutch to arrive from the US and need to decide on a fuel pump setup. Hopefully we will get the car finished by the end of April Quote Link to comment Share on other sites More sharing options...
Big Supes Posted March 21, 2015 Share Posted March 21, 2015 Awesome project. I've always liked the 350z, but they lack heart... this one won't though, that's for sure! Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted March 26, 2015 Share Posted March 26, 2015 Looking good mate Should be a nice build. Quote Link to comment Share on other sites More sharing options...
Ian. Posted March 27, 2015 Author Share Posted March 27, 2015 Actually starting to see some progress on the car now Front suspension assembled and front brakes fitted Quote Link to comment Share on other sites More sharing options...
supra matt Posted March 28, 2015 Share Posted March 28, 2015 Looking very nice mate looking forward to seeing this up and running , Quote Link to comment Share on other sites More sharing options...
Ian. Posted April 25, 2015 Author Share Posted April 25, 2015 Quite a bit has happened to the Zupra since the last update. Japfest is still looking like an unrealistic target though Fitted the exhaust ready to measure for the custom middle section to downpipe Wiring harness turned up Walbro 450LPH fuel pump Its quite low ARC intercooler mocked up GTSpec wing braces A long lost friend turned up! The bottom end even got mounted! Doesnt quite fit though due to using the 350Z gearbox. Will need custom mounts for the box now to move it back a few inches, which will also require a custom prop shaft and some fiddling with the gear linkage. Still, its a bit of progress which has been severely lacking of late! Quote Link to comment Share on other sites More sharing options...
hiten55 Posted April 28, 2015 Share Posted April 28, 2015 How did i miss this? [emoji15] looks interesting - subscribed[emoji16] Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 18, 2015 Share Posted May 18, 2015 I may be overreacting but isn't using a mangy lifting strop to sandpaper the bores of cylinders 2 and 5 a bit risky? It's doing the mains bearing surfaces underneath as well, I'd imagine... Quote Link to comment Share on other sites More sharing options...
Pudsey Posted May 18, 2015 Share Posted May 18, 2015 Impressive build - I missed this one too. That's a lot of money going into the parts for the front end, looks great. Look forward to following your progress, and really like the tail pipe silencer vivid colours. Pretty damn special that Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted May 19, 2015 Share Posted May 19, 2015 Id love to do this to the girlfriends 350z project looks awesome mate oh and what back box is that? Love the colour Quote Link to comment Share on other sites More sharing options...
Ian. Posted May 20, 2015 Author Share Posted May 20, 2015 The exhaust is made by Agency Power A few more pics Custom gearbox mount Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted May 20, 2015 Share Posted May 20, 2015 Might have missed it but what sort of power you aiming for? Quote Link to comment Share on other sites More sharing options...
Ian. Posted May 20, 2015 Author Share Posted May 20, 2015 If I get to 700 I'll be happy. My mate whos building it is aiming for that as a minimum Had to modify the manifold a bit to fit into the 350Z but its now done Quote Link to comment Share on other sites More sharing options...
jimojameso Posted May 20, 2015 Share Posted May 20, 2015 How's this coming on? Ooops edit. Posted at the same time. Quote Link to comment Share on other sites More sharing options...
Ian. Posted May 20, 2015 Author Share Posted May 20, 2015 How's this coming on? Ooops edit. Posted at the same time. Hopefully will be firing the engine soon, just need to bolt a few more things together and we are ready for the first start In terms of completing the build, I think its looking like mid-late June depending on who maps it Quote Link to comment Share on other sites More sharing options...
jimojameso Posted May 20, 2015 Share Posted May 20, 2015 Good work. Look forward to seeing it running! Quote Link to comment Share on other sites More sharing options...
