jza800 Posted December 28, 2014 Share Posted December 28, 2014 I have now bourgt the gizzmo ms2 controller from a member inhere, but need some advise and help on setting and wirring.. first of all on the relay there are 3 wirring. red: constant 12v blue: ignition 1 (somebody know what wire to connect on) yellow/green : ignition 2 (should i need this? if yes what wire) then i need some help on the solenoid to connect to my wastegate, i belive that i have to use port 2 and 3 on the solenoid to the wastegate port 2: goes to the wastegate? port 3: goes to the turbohouse? And then to the settings.. i now gain is how fast it goes to boost and duty is max boost.. my target is around 1.2 bar, i now it is difficult to give the accurate numbers, but is to only so i have someting to start at, so i dont put in some wrong numbers and make some damage on the engine or turboes gain: ? duty: ? Quote Link to comment Share on other sites More sharing options...
jza800 Posted December 29, 2014 Author Share Posted December 29, 2014 bump Quote Link to comment Share on other sites More sharing options...
thomo8568 Posted December 29, 2014 Share Posted December 29, 2014 http://www.gizzmoelectronics.co.uk/pdf/MS-IBC%20Instruction%20PDF%20Ver1.01.pdf Quote Link to comment Share on other sites More sharing options...
jza800 Posted December 29, 2014 Author Share Posted December 29, 2014 I have the manual.. need some that have mountet in their supra... Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 29, 2014 Share Posted December 29, 2014 For the settings, start with about 15 gain, and 50 duty. That should be about 1.2 bar. As for the wiring, surely if you have the manual, it can't be that difficult to figure out. My msibc was just power and earth, I'm not sure you need the other wires unless you plan to use the turbo timer function? Quote Link to comment Share on other sites More sharing options...
jza800 Posted December 29, 2014 Author Share Posted December 29, 2014 (edited) yes but it have 2 ignitions wire, i now i hve to use one off them, otherwise the display do not turn on.. blue: ignition 1 (somebody know what wire to connect on) yellow/green : ignition 2 (should i need this? if yes what wire) and how about the solenoid, is that the right way to Mount it on the turboes??? 2 goes to actuator 3 goes to turbo 1 housning right?? stock tt engine Edited December 29, 2014 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 29, 2014 Share Posted December 29, 2014 I would never listen to anyone telling me what wire in the car to connect to. Buy a multimeter and check yourself. You only need to find a switched live, under the ignition or behind the radio If you're unsure which one on the gizzmo to use, just connect them both - it won't do any harm. If the instructions say connect port 2 to the actuator, and port 3 to the compressor housing, then do that. You must leave the unused port on the solenoid open Quote Link to comment Share on other sites More sharing options...
jza800 Posted December 29, 2014 Author Share Posted December 29, 2014 it only shows 2 Pictures, the one i postet, and for external wastegate... Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 29, 2014 Share Posted December 29, 2014 Then that's correct mate. Quote Link to comment Share on other sites More sharing options...
jza800 Posted December 29, 2014 Author Share Posted December 29, 2014 ok, thanks, i will trie with the setting you wrote, i can see that a can set a overboost, should i use it or not??? Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 29, 2014 Share Posted December 29, 2014 It would be wise to set it if possible, but I don't know whether it's a visual thing, or whether it actually lowers the boost automatically on this model? If you set it up this time of year, you shouldn't have to worry about overboosting, as it's not likely to get much colder lol! Quote Link to comment Share on other sites More sharing options...
jza800 Posted December 29, 2014 Author Share Posted December 29, 2014 Ok, if i set it, what should i set it at then??? Hehe, no this car dont run at the wintertime Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 29, 2014 Share Posted December 29, 2014 Well, if you want to run a max of 1.2 bar for instance, I'd set the overboost to 1.25. Quote Link to comment Share on other sites More sharing options...
jza800 Posted March 24, 2015 Author Share Posted March 24, 2015 i have a quistion about connection of the solenoid on my gizzmo as the Picture confuse me, port 2: actuator port 3 :compressor housing on turbo 1 or does it have to be connectet to the intake??? for as the Picture show it has to be connectet to the pipe that goes to the intercooler??? Quote Link to comment Share on other sites More sharing options...
jza800 Posted March 26, 2015 Author Share Posted March 26, 2015 nobody know this controller?? is it posible to turn it off, so i have stock boost level??? Quote Link to comment Share on other sites More sharing options...
Grasmt Posted March 26, 2015 Share Posted March 26, 2015 Put a 1bar restrictor ring in the exhaust plumb all the vacuums back to their original places and take the boost controller out all together. Stock boost(ish) Quote Link to comment Share on other sites More sharing options...
jza800 Posted March 27, 2015 Author Share Posted March 27, 2015 That was not the quistion, i now many boost controller can be turn of, and you then have stock boost level.. have read the manual many times with no luck. Quote Link to comment Share on other sites More sharing options...
