Welding diffbushes help
Guest JapEmil
Guest JapEmil
okey, i had the subframe off when i welded it, i just welded the rear side not the diffside!
But it came to my mind that maybe that's not gonna hold!
But il go with just one side welded and hope thats it hold :)
Thanx for answers everyone :)
And sorry again for my very vad english :p
Guest JapEmil
You *MUST* also run solid bushes on the front of the diff as well, not a mix of rubber and solid! Personally I would get a competent turner to make some press fit solid mounts in case the noise drives you crazy. That way you can go back to rubber...
I have already fit the front diff bushes! Cnc aluminium press in :)
