MATT RR Posted December 24, 2014 Share Posted December 24, 2014 Hi Guys, Just wondering if there is a guide to changing spark plugs on the VVTI TT, I've been searching and found some old links that don't seem to work, does anyone have the link to the how to? I have changed them on a pre-VVTI before but just wanted to check and refresh before doing it on the VVTI, is the only difference 3 coil packs instead of 6? Also I understand 13ft/lbs is the correct torque setting is that right? Thanks in advance for your help and merry Christmas Matt Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted December 24, 2014 Share Posted December 24, 2014 Same way you do it on a non VVTI. Only difference are the coil packs as you said Quote Link to comment Share on other sites More sharing options...
