oil in intake pipe
jawan
hi,
recently replaced my turbos on Jspec TT auto
before it was smoking when Decelerating.
Now replaced turbos, no smoke but getting lots of oil in air filter pipe.
the only other difference between now and before is that the valve in downpipe area was permanently open before I changed the turbos, now it is in standard form.
Please see picture of the valve I am referring too.
not sure what is causing this. any ideas
thanks
Edited by jawan (see edit history)
how much oil is there in the pipes? are the new turbos just a second hand set, or refurbed, or new? a very slight film isn't a problem but if there is lots, especially after fitting new or refurbed, then you have a problem.
I don't know how your car was running ok if the E G C V was stuck one way or the other, it should open and close as you go from 1st to 2nd turbo and back again.
