gavin.starr Posted December 20, 2014 Share Posted December 20, 2014 When I sent my cam cover's off for powder coating the guy behind the counter said he could not promise that he would be able to keep all the shot blasting out from underneath the breather plates. So since i got them back i have wanted to remove the plates and give them a good clean out, As the last thing i want is some shot blast media floating around near my cams when the engine all goes back together. So here is my little walk through Firstly I started with a hammer and a punch on the raised squashed riveted holding points. I used the punch just to help guide the first drill into place without it wandering. I used a small 2.5mm drill to get things going. I then stepped up to a 5mm drill to open out the holes. Once I drilled them out i used another 5mm drill bit, using the blunt end I inserted it into the hole and gave it some leverage to crack off the remainder of the rivet. Once all the rivets had been removed i could remover the plate, And my word there was som crud underneath. So out came the bottle of Acetone and a tooth brush to clean all the parts up, Obviously keeping it well away from the painted side of my cam cover's. Once the parts were cleaned and the gunk removed I set my mind on drilling and tapping some holes to accept my new stainless 4mm thread bolts. I used a 3.2mm drill and a set of three taps, first, second and final cut, all though just the final cut would be fine. Once all the holed had been drilled and tapped, I proceeded to re-seal the plates and re-install them to the cam cover's. I used some lock tight to hold the bolts in place as i dont want them coming undone. I then ran up the bolts and cleaned up the excess sealant. Bish bash bosh job done and i now know there is nothing inside them that may cause damage to my engine. Gav Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 20, 2014 Share Posted December 20, 2014 Nice guide there. Thanks for sharing Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted December 20, 2014 Share Posted December 20, 2014 Great guide To anyone looking at doing this, make sure you do it BEFORE sending them off for shot blasting and powdercoating! Just out of interest, what was the ballpark figure for getting them done? Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted December 21, 2014 Share Posted December 21, 2014 Am I the only one worried that one day a bolt will work it's way loose and go on an adventure with your cams? I worry easily about stuff like that Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 21, 2014 Share Posted December 21, 2014 You could use some aluminium bar, cut to length and press into the holes, weld in place then peen the head over once the baffle plate is re fitted I'd be doing this before shot blasting and powder coating, you can also clean the covers up like new using Phosphoric acid Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 21, 2014 Share Posted December 21, 2014 Am I the only one worried that one day a bolt will work it's way loose and go on an adventure with your cams? I worry easily about stuff like that Err, this is why he correctly Loctited them in place It's not just blast media getting amongst the cams, it will be carried down into the sump and through the coarse mesh of the pick up strainer, into the oil pump and beyond. Removing the baffle plates is a MUST when doing this sort of prettying up of the covers. Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted December 21, 2014 Share Posted December 21, 2014 Yeah it's been helpful seeing this thread, I intend on sorting out my cam covers in future and didn't realise the baffle plates were fitted with rivets so it's good to know what process is best to use for when I come to do it Reminds me, my mate has had my tap and die set for the last 2 years! I need that back grrr Quote Link to comment Share on other sites More sharing options...
