JayJay1374 Posted December 19, 2014 Share Posted December 19, 2014 I've been getting a strange electric fault inside the car since I first bought it. Anyway the problem..... Driving along as normal then there's a click noise, all the dials go off, heaters go off, doors unlock if locked, windows don't work. The lights stay on on the Custer, no warning lights come up. Then if I just touch the key it all comes back to life. This fault originally happened once every few months. It's now becoming more common. Which is just annoying. Also I have noticed my door lock switch is very sensitive. Press as normal to lock but you barely have to touch the unlock side and it unlocks. Any advise is welcome Link to comment Share on other sites More sharing options...
np89 Posted December 19, 2014 Share Posted December 19, 2014 Sounds like a loose / bad connection at the second accessory on the key. Maybe a relay due to the click? Link to comment Share on other sites More sharing options...
JayJay1374 Posted December 19, 2014 Author Share Posted December 19, 2014 Just had a look in the workshop manual. Only relay it could be is the main power relay. Gonna have a check tomorrow. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 20, 2014 Share Posted December 20, 2014 Ignition switch itself? Link to comment Share on other sites More sharing options...
JayJay1374 Posted December 20, 2014 Author Share Posted December 20, 2014 I've changed the lock set, it was doing it before I changed the locks. Link to comment Share on other sites More sharing options...
