marc_p Posted January 6, 2015 Share Posted January 6, 2015 Thanks Dude But there's no point , I will still have 22 year old ball joints. I have the front done in Super Pro and between the labour cost to press in and out the bushes , it much of a muchness but with the benefit of new Ball joints Unless your ball joints are knackered, then there is no need to replace them. I also did the bushes myself, so no labour cost, as long as you have a vice, sockets(and maybe a blow torch), then you can always do them yourself . Link to comment Share on other sites More sharing options...
jot_ie Posted January 6, 2015 Share Posted January 6, 2015 I am replacing the entire rear suspension, (both sides), except for shocks, after my car was stolen and damaged some time ago, with all new oem parts. Upper and lower control arms, both sides, all new nuts and bolts, axle carriers, bearings, hubs, drop links as well as one new half shaft and speed sensor. Cost was around the 3K mark but remember that's in Euros here in Ireland, and the Toyota garage is giving me a 20% discount. For example I paid the equivalent of £272 (including Irish VAT @23% but with a Toyota 20% discount), for one rear upper control arm. I have heard these are around the £400 mark in the UK. For once something in Ireland is cheaper :-) John Link to comment Share on other sites More sharing options...
Jellybean Posted January 6, 2015 Author Share Posted January 6, 2015 Toyota Ireland are cheaper than the UK even with Traders Special prices on here I even priced up Toyota USA and Toyota Ireland are still cheaper , waiting on prices from Japan All prices in Euro Front 48630-19025 ARM ASSY, FRONT SUSPENSION, UPPER LH discontinued 48610-19025 ARM ASSY, FRONT SUSPENSION UPPER, RH discontinued 48068-14080 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 RH 237.85 48069-14080 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 LH 237.85 Rear 48770-19025 ARM ASSY, UPPER CONTROL, REAR RH 373.92 48790-19025 ARM ASSY, UPPER CONTROL, REAR LH 373.92 48710-14110 ARM ASSY, REAR SUSPENSION, NO.1 RH 139.18 48710-14110 ARM ASSY, REAR SUSPENSION, NO.1 LH 139.18 8725-14070 BUSH, REAR AXLE CARRIER, LH 25.39 3+4 weeks 48725-14070 BUSH, REAR AXLE CARRIER, RH 25.39 3+4 weeks 48818-14050 BUSH, STABILIZER, REAR 7.11 each 45460-19235 Track Rod RH 69.31 2 days 45470-19065 Track Rod LH 69.31 48830-14050 LINK ASSY, REAR STABILIZER, RH 58.67 3+4 weeks 48840-14030 LINK ASSY, REAR STABILIZER, LH 58.67 2days 48820-24010 LINK ASSY, FRONT STABILIZER, LH 63.28 48820-24010 LINK ASSY, FRONT STABILIZER, RH 63.28 48815-14080 BUSH, FRONT STABILIZER BAR, NO.1 12.81 each x2 Link to comment Share on other sites More sharing options...
Ric Posted January 6, 2015 Share Posted January 6, 2015 that Amayama website or whatever it was was 1400quid for a full set of arms and tie rods Link to comment Share on other sites More sharing options...
Jellybean Posted January 8, 2015 Author Share Posted January 8, 2015 So good news on top of the Prices I have posted from Toyota Ireland above (in Euro), they are giving me a 20% Discount Link to comment Share on other sites More sharing options...
dangerous brain Posted March 22, 2015 Share Posted March 22, 2015 Discontinued? What are we supposed to do about replacement arms if toyota begin discontinuing this stuff? I need some front suspension arms by the sounds of it as I sold the car this week not realising the MOT had run out. To get it through the MOT it will need some suspension bits as it had started knocking at the front end. Does anybody know what the front end parts cost from Toyota with Steve Manleys discount? Toyota Ireland are cheaper than the UK even with Traders Special prices on here I even priced up Toyota USA and Toyota Ireland are still cheaper , waiting on prices from Japan All prices in Euro Front 48630-19025 ARM ASSY, FRONT SUSPENSION, UPPER LH discontinued 48610-19025 ARM ASSY, FRONT SUSPENSION UPPER, RH discontinued 48068-14080 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 RH 237.85 48069-14080 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 LH 237.85 Rear 48770-19025 ARM ASSY, UPPER CONTROL, REAR RH 373.92 48790-19025 ARM ASSY, UPPER CONTROL, REAR LH 373.92 48710-14110 ARM ASSY, REAR SUSPENSION, NO.1 RH 139.18 48710-14110 ARM ASSY, REAR SUSPENSION, NO.1 LH 139.18 8725-14070 BUSH, REAR AXLE CARRIER, LH 25.39 3+4 weeks 48725-14070 BUSH, REAR AXLE CARRIER, RH 25.39 3+4 weeks 48818-14050 BUSH, STABILIZER, REAR 7.11 each 45460-19235 Track Rod RH 69.31 2 days 45470-19065 Track Rod LH 69.31 48830-14050 LINK ASSY, REAR STABILIZER, RH 58.67 3+4 weeks 48840-14030 LINK ASSY, REAR STABILIZER, LH 58.67 2days 48820-24010 LINK ASSY, FRONT STABILIZER, LH 63.28 48820-24010 LINK ASSY, FRONT STABILIZER, RH 63.28 48815-14080 BUSH, FRONT STABILIZER BAR, NO.1 12.81 each x2 Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 23, 2015 Share Posted March 23, 2015 Toyota has had MKIV stuff disappearing off the parts list for years. I try and buy new old stock from time to time. Depending just what is discontinued the options are repair, recreate or re-engineer. The logistics of this vary as to whether you are talking anti roll bar link (trivial) or a differential crown wheel and pinion, (far from trivial, excruciatingly expensive in very small quantities, and probably easier to transplant a diff from something else if used ones dry up). A "spares" car or 3 makes sense if you are one of those people who claim "I will NEVER *EVER* sell it!" Link to comment Share on other sites More sharing options...
jazz1 Posted March 23, 2015 Share Posted March 23, 2015 The front Arms are still available is Japan, hurry up . Link to comment Share on other sites More sharing options...
Jellybean Posted March 23, 2015 Author Share Posted March 23, 2015 Just buy a 3d printer Link to comment Share on other sites More sharing options...
