Jellybean Posted December 19, 2014 Share Posted December 19, 2014 Cars are getting old now November 2009 : Front Arms and Steering rack are Super Pro Polybrushed but ball joints are high mileage (I did change one but I get ripped off with a second hand part even though I paid for a new) , I would reckon at least 45-50K miles on these now Question Suspension arms , what would you recommend , replace everything with OEM or just the lower front arms (to get new ball joints) and polybrush the rear ? I think this is all I would need , was thinking of super pro the rear struts (ROD ASSY, STRUT, REAR) Front 48630-19025 ARM ASSY, FRONT SUSPENSION, UPPER LH 48610-19025 ARM ASSY, FRONT SUSPENSION UPPER, RH 48068-14080 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 RH 48069-14080 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 LH Rear 48770-19025 ARM ASSY, UPPER CONTROL, REAR RH 48790-19025 ARM ASSY, UPPER CONTROL, REAR LH 48710-14110 ARM ASSY, REAR SUSPENSION, NO.1 RH 48710-14110 ARM ASSY, REAR SUSPENSION, NO.1 LH 8725-14070 BUSH, REAR AXLE CARRIER, LH 48725-14070 BUSH, REAR AXLE CARRIER, RH 48818-14050 BUSH, STABILIZER, REAR Link to comment Share on other sites More sharing options...
Gaz6002 Posted December 19, 2014 Share Posted December 19, 2014 OEM all the way, for me. Crucial parts of the car! Link to comment Share on other sites More sharing options...
Nic Posted December 19, 2014 Share Posted December 19, 2014 OEM all the way, for me. Crucial parts of the car! When I overhauled my suspension with new OEM parts it completely transformed the car, the best money I ever spent on it. Ian did a good write up HERE Link to comment Share on other sites More sharing options...
Jellybean Posted December 19, 2014 Author Share Posted December 19, 2014 When I overhauled my suspension with new OEM parts it completely transformed the car, the best money I ever spent on it. Ian did a good write up HERE thanks missed that Link to comment Share on other sites More sharing options...
jonc Posted December 19, 2014 Share Posted December 19, 2014 (edited) I re bushed with R2R bushes from MVP and it transformed my car 2 years ago. A bitch of a job though:rolleyes:. I also have the Geo done every year now the suspension is done. In fact it made such a difference it showed up how woolly the steering was so I have just renewed the steering rack. MVP didn't have R2R bushes in stock for the new rack so I went with Superpro. I would say if you have the money Toyota parts are the way to go. I would think most Supras have loose suspension now unless they have had the work done. Edited December 19, 2014 by jonc (see edit history) Link to comment Share on other sites More sharing options...
jazz1 Posted December 19, 2014 Share Posted December 19, 2014 Trust me guys go OEM all the way, the cost to replace all underside is not too bad! Link to comment Share on other sites More sharing options...
Jellybean Posted December 19, 2014 Author Share Posted December 19, 2014 Trust me guys go OEM all the way, the cost to replace all underside is not too bad! The cost I am expecting to be eye watering , 3 digits Link to comment Share on other sites More sharing options...
pedrosixfour Posted December 19, 2014 Share Posted December 19, 2014 The cost I am expecting to be eye watering , 3 digits I think you might be missing a digit there mate. Link to comment Share on other sites More sharing options...
jjs_82 Posted December 19, 2014 Share Posted December 19, 2014 LOL. You will not get much with 3 digits Link to comment Share on other sites More sharing options...
Jellybean Posted December 19, 2014 Author Share Posted December 19, 2014 (edited) lol I mean the amount of zeros after, easy I reckon 3K euro mark 2622 off Whifbitz Edited December 19, 2014 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted December 19, 2014 Author Share Posted December 19, 2014 Anybody use Pattern track rod ends andRoll Bar Links of tcb parts? http://www.tcbparts.co.uk/ Link to comment Share on other sites More sharing options...
j_jza80 Posted December 19, 2014 Share Posted December 19, 2014 Facelift or pre facelift? Link to comment Share on other sites More sharing options...
Jellybean Posted December 19, 2014 Author Share Posted December 19, 2014 Facelift or pre facelift? ??? Link to comment Share on other sites More sharing options...
jazz1 Posted December 19, 2014 Share Posted December 19, 2014 The cost I am expecting to be eye watering , 3 digits Facelift is very slight more, but if your looking to replace everything from wheel bearings the whole lot etc than around 4,600. Link to comment Share on other sites More sharing options...
Jellybean Posted December 19, 2014 Author Share Posted December 19, 2014 Facelift is very slight more, but if your looking to replace everything from wheel bearings the whole lot etc than around 4,600. Wheel bearings are all good , just the bushes and ball joints Link to comment Share on other sites More sharing options...
jazz1 Posted December 19, 2014 Share Posted December 19, 2014 Wheel bearings are all good , just the bushes and ball joints Probably around 2-3k I would say, get a new set as replacing bushes won't replace wishbone bearings etc. Link to comment Share on other sites More sharing options...
pedrosixfour Posted December 20, 2014 Share Posted December 20, 2014 Anybody use Pattern track rod ends andRoll Bar Links of tcb parts? http://www.tcbparts.co.uk/ Haven't used anything from that particular site but I do have a Blueprint track rod end fitted to the car and it is certainly a well made part. There is probably a fair chance their offering is also a Blueprint item. Link to comment Share on other sites More sharing options...
Jellybean Posted December 20, 2014 Author Share Posted December 20, 2014 Haven't used anything from that particular site but I do have a Blueprint track rod end fitted to the car and it is certainly a well made part. There is probably a fair chance their offering is also a Blueprint item. i reckon so , for the price difference i think its worth a punt Link to comment Share on other sites More sharing options...
Parry_10 Posted December 20, 2014 Share Posted December 20, 2014 I used a pattern anti roll bar drop link it was no good. Knocking within a couple of weeks. Go oem not that expensive. Link to comment Share on other sites More sharing options...
Jellybean Posted December 20, 2014 Author Share Posted December 20, 2014 I used a pattern anti roll bar drop link it was no good. Knocking within a couple of weeks. Go oem not that expensive. Cool thanks! for the heads up Link to comment Share on other sites More sharing options...
Jellybean Posted January 5, 2015 Author Share Posted January 5, 2015 the 48725-14070 BUSH, REAR AXLE CARRIER, LH & RH , TCB said I need 4 of them ; looking at ToyoDiy I think I just need two , RH and LH? http://www.toyodiy.com/parts/p_J_1993_TOYOTA_SUPRA_JZA80-ALFQZ_4804.4.html?hl=48725F Link to comment Share on other sites More sharing options...
dangerous brain Posted January 5, 2015 Share Posted January 5, 2015 I've used blueprint replacement ball joints and suspension arms http://clubaristo.net/forums/attachment.php?attachmentid=9659&d=1288686222 1 of ZADT38692[1] Blueprint ADT Part Numbers UPPER SUSPENSION ARM - ADT38692 Total Price £46.50 1 of ZADT386120[1] Blueprint ADT Part Numbers LOWER BALL JOINT - ADT386120 Total Price £52.30 Those are the aristo components but I don't think the supra ones are much different. Link to comment Share on other sites More sharing options...
Jellybean Posted January 5, 2015 Author Share Posted January 5, 2015 I've used blueprint replacement ball joints and suspension arms http://clubaristo.net/forums/attachment.php?attachmentid=9659&d=1288686222 1 of ZADT38692[1] Blueprint ADT Part Numbers UPPER SUSPENSION ARM - ADT38692 Total Price £46.50 1 of ZADT386120[1] Blueprint ADT Part Numbers LOWER BALL JOINT - ADT386120 Total Price £52.30 Those are the aristo components but I don't think the supra ones are much different. The Supra ones are cast into the Arm, as far as I know the whole arm needs to be replaced to replace the ball joint Link to comment Share on other sites More sharing options...
marc_p Posted January 6, 2015 Share Posted January 6, 2015 I'd personally go with the Super Pro bushes, I have replaced all of my bushes with Super Pro(bar the rear upper arms as these are pillowball) and the ride is the best I have experianced, it's tight, but not crashy or hard, much better than OEM, mixed with my Tein Flex coilovers(on a soft setting), it is the best ride I have experienced in a long time, it's better than my e92 3-Series. Link to comment Share on other sites More sharing options...
Jellybean Posted January 6, 2015 Author Share Posted January 6, 2015 I'd personally go with the Super Pro bushes, I have replaced all of my bushes with Super Pro(bar the rear upper arms as these are pillowball) and the ride is the best I have experianced, it's tight, but not crashy or hard, much better than OEM, mixed with my Tein Flex coilovers(on a soft setting), it is the best ride I have experienced in a long time, it's better than my e92 3-Series. Thanks Dude But there's no point , I will still have 22 year old ball joints. I have the front done in Super Pro and between the labour cost to press in and out the bushes , it much of a muchness but with the benefit of new Ball joints Link to comment Share on other sites More sharing options...
