shetlandsupra Posted December 18, 2014 Share Posted December 18, 2014 My oil pressure is reading off the gauge and as I went to turn the car off the oil filter seals blew any ideas what up? Link to comment Share on other sites More sharing options...
Dazzi Posted December 18, 2014 Share Posted December 18, 2014 Oil pump pressure release valve Link to comment Share on other sites More sharing options...
MattP Posted December 18, 2014 Share Posted December 18, 2014 http://www.mkivsupra.net/vbb/showthread.php?312926-Major-Oil-Leak-(&highlight=Major+oil+leak Link to comment Share on other sites More sharing options...
shetlandsupra Posted December 18, 2014 Author Share Posted December 18, 2014 It's a brand new oil pump is it a fault of the relief valve? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 18, 2014 Share Posted December 18, 2014 Always worth checking...I had a brand new pump and found it wouldn't even turn. Link to comment Share on other sites More sharing options...
shetlandsupra Posted December 18, 2014 Author Share Posted December 18, 2014 Okay what a nightmare! Brand new from Toyota you'd think it would be perfect Link to comment Share on other sites More sharing options...
Lee P Posted December 19, 2014 Share Posted December 19, 2014 Probably an incorrectly fitted front main seal, even 1mm into far and it will leak. You always get alot of oil pressure when cold that's perfectly normal What was it reading? Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 19, 2014 Share Posted December 19, 2014 If you have any extra plumbing for the oil system, like an oil cooler or oil cooler thermostat plate it's probably plumbed wrong, or the oil pressure relief valve in the pump is stuck shut. The valve is accessible externally with the cam belt off. I would suspect dirt has made it stick. DO NOT over tighten the cap nut holding the relief valve and spring in, you WILL crack the pump housing. Ring me for how to get a stuck valve out, no time to type it all up. DO NOT try and start it again. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 19, 2014 Share Posted December 19, 2014 Probably an incorrectly fitted front main seal, even 1mm into far and it will leak. You always get alot of oil pressure when cold that's perfectly normal What was it reading? A lot if it's blown the oil filter seal out, or split the filter Can't see it being the front seal. Link to comment Share on other sites More sharing options...
Lee P Posted December 19, 2014 Share Posted December 19, 2014 A lot if it's blown the oil filter seal out, or split the filter Can't see it being the front seal. My bad, I miss read it. Thought he ment FMS Link to comment Share on other sites More sharing options...
shetlandsupra Posted December 20, 2014 Author Share Posted December 20, 2014 The reading was off the defi gauge over 10 I'll chexk the relief valve on Monday thanks Link to comment Share on other sites More sharing options...
shetlandsupra Posted December 20, 2014 Author Share Posted December 20, 2014 Only things to oil I did was crank seal,new oil pump, hks filter and Sandwich plate Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 20, 2014 Share Posted December 20, 2014 Hmmm, sandwich plate eh? Before doing anything else take it off and put it back to stock and (very quicly and carefully) try it again. The two problems with defi gauges are: A: Thay are junk, IMHO B: They furtle about resetting the needle at just the moment you want an immediate pressure reading, (during and after cranking). I always use a basic mechanical gauge for oil and fuel pressure if the budget doesn't allow for high end electronic gauges and senders. Or the set up has a digital dash with a good sender. Even in a high end set up, when doing it for myself, I use a mechanical oil pressure and fuel pressure gauge. Link to comment Share on other sites More sharing options...
