alxns7 Posted December 18, 2014 Share Posted December 18, 2014 (edited) Hello, My front wheels are currently 18x9.5" +22 wheels with 235/40 tyres, so they are stretched. The former owner found a used set of four Volk TE37 off a GTR, all of that same size. It was probably a great deal but unfortunately finding used TE37 wheels in the right size is very difficult. I'm close to finding wheels of the right size (18x8.5" +30, of which I believe the offset is the right one) and was wondering if just putting the stretched tyres on the new wheels would be a problem? I've never personally seen a tyre being fitted but was thinking maybe a stretched tyre would cause trouble fitting a narrower wheel? The tyres are fairly new (only 600 km on the 18x9.5). I don't think it would be a problem but I might be wrong. Cheers Alex Edited December 18, 2014 by alxns7 (see edit history) Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted December 18, 2014 Share Posted December 18, 2014 Unless the tyre sidewall was damaged due to being stretched I can't see any problem, a good tyre will return to its original shape once off the 9.5" rim and will suit the 8.5" rim much better. I run 285/30 tyres on my 9.5" rears and 255/35 on my 8.5" fronts. Je deteste le stretch. For the record, it is ok to use the same width rim front & rear on a Supra, it might tend to oversteer a bit more due to the levels of grip offered by similar width wheels & tyres but this may be to your liking. Quote Link to comment Share on other sites More sharing options...
alxns7 Posted December 19, 2014 Author Share Posted December 19, 2014 Alright thanks for the input, i'm gonna go for it. I want to change them because this +22 offset on 9.5" is just too much in the front. After some measures i think +30 on 8.5" would be the best, but 8.5" +22 would probably also be ok. The 9.5" +22 look great in the rear. Quote Link to comment Share on other sites More sharing options...
