Mike2JZ Posted December 16, 2014 Share Posted December 16, 2014 So driving to Medway today and the heater water pipe that exits behind the bulkhead has split. So pissing coolant and looks like I'm not getting home. Before I give up and call recovery, is there anything that people can think of to try to seal the split, at least short term. I've tried exhaust heating tape and gaffer but still getting a leak Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 16, 2014 Share Posted December 16, 2014 Can you bung both hoses and bypass the heater matrix? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted December 16, 2014 Share Posted December 16, 2014 I used one of these to isolate my heater matrix http://www.dixonhall.co.uk/app/users_content/product_images/full/product_1356_full_1.jpg You'd need to order them from a plumbers merchants - Yorkshire Fittings YP20 15mm return bend. Fits inside the pipe perfectly. Then use suitable jubilee clips. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted December 16, 2014 Share Posted December 16, 2014 Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 16, 2014 Author Share Posted December 16, 2014 The issue isn't with the heater matrix leaking, sorry if that was unclear. The hose going out the bulkhead that goes onto the matrix has split by the bulkhead, so I can't really put a bung in very easily. Anyway, leaving the car parked up overnight and will trailer it tomorrow to get sorted. Shit happens I guess Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted December 16, 2014 Share Posted December 16, 2014 you mean these pictured? If so they need to be replaced, they go straight into the HM Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 16, 2014 Author Share Posted December 16, 2014 No behind the engine itself, thought that was called the bulkhead maybe not Quote Link to comment Share on other sites More sharing options...
Littler Posted December 16, 2014 Share Posted December 16, 2014 (edited) I think you are referring to the pipe that comes out the back of the head and the one that isn't easy to get to! It leads to one of the heater matrix pipes but the leak is nearer the outlet on the head which is a pain to get to? Edited December 16, 2014 by Littler edit (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 16, 2014 Author Share Posted December 16, 2014 Exactly that littler . Gonna have some fun trying to fix that tomorrow Quote Link to comment Share on other sites More sharing options...
MattP Posted December 16, 2014 Share Posted December 16, 2014 This one Quote Link to comment Share on other sites More sharing options...
MattP Posted December 16, 2014 Share Posted December 16, 2014 Nevermind I see Quote Link to comment Share on other sites More sharing options...
The Raven Posted December 17, 2014 Share Posted December 17, 2014 Dude you and your heater! Where is the car? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 17, 2014 Share Posted December 17, 2014 If you had taped it up as best as you could, then left the rad cap on the first detent so it was not able to seal, the system wouldn't pressurise. It would probably have got you back with a top or two. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 17, 2014 Share Posted December 17, 2014 I had the same hose go just before jae '13. Was a total sod to replace, the new one was about £30 from Toyota iirc. Easiest way, is to whip the cam covers off. Makes it much, much easier! Quote Link to comment Share on other sites More sharing options...
