trooper Posted September 2, 2005 Share Posted September 2, 2005 After two years, almost to the day, of Supra ownership I have my first fault with the car. When I put my lights on, the gear selector letters (automatic) in the centre console no longer light up!! And I thought these cars were meant to be reliable!!! LOL This means I'll have to replace the bulb and they probably cost the best part of £1. Link to comment Share on other sites More sharing options...
Stu_Fraser Posted September 2, 2005 Share Posted September 2, 2005 The same lights on mine stopped working for about a month, then one day decided to come back on. No idea what the problem was. Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted September 2, 2005 Share Posted September 2, 2005 don't think mine ever have done I'd like to know how to fix this too. Bloody Toyota PITA!! Link to comment Share on other sites More sharing options...
Bob Posted September 2, 2005 Share Posted September 2, 2005 I think it may be down to a loose connection - my letters weren't working until I took the dash out, fiddled about looking at bulbs, and then put it back. Hey presto, all working now! Link to comment Share on other sites More sharing options...
TrickTT Posted September 2, 2005 Share Posted September 2, 2005 Bo[[ocks. I didn't know the letters by the shifter were supposed to light up (thought it was just the lights in the rev counter. Got to go and take mine apart now. Link to comment Share on other sites More sharing options...
Bob Posted September 2, 2005 Share Posted September 2, 2005 Ah, I was talking about the lights on the gauges. Sorry, work tends to muddle my already muddled brain Link to comment Share on other sites More sharing options...
JohnA Posted September 2, 2005 Share Posted September 2, 2005 I had the same with the active spoiler light. It wouldn't come on, I thought it needed replacement. After a few days it came on, like nothing ever happened. I thought these cars were meant to be reliable, lol... Link to comment Share on other sites More sharing options...
TrickTT Posted September 2, 2005 Share Posted September 2, 2005 Ah, I was talking about the lights on the gauges. Sorry, work tends to muddle my already muddled brain If you're talking about the lights in the rev counter, its a PITA, and start saving - toyota bulbs are not cheap. Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted September 3, 2005 Share Posted September 3, 2005 Just checked and my gear selector lights do work at night. Just never noticed them before. Nice to know anyhow Link to comment Share on other sites More sharing options...
trooper Posted September 5, 2005 Author Share Posted September 5, 2005 I took the plastic off from around the gear lever etc to look for the bulb. Found what could be a bulb at the back, close to the driver's side. Seemed like it was glued in or something! Didn't want to force it and break it. Damn. Does this twist out or something? It's just a small bulb like a fairy light!! Link to comment Share on other sites More sharing options...
TrickTT Posted September 5, 2005 Share Posted September 5, 2005 its under the 'N' of the selector twist it 1/4 turn anticlockwise and pull down. Might be easier if you loosen the 4 screws holding down the selector. You will need a standard push fit panel bulb (£1.00 from the local motor factors), and fit the green plastic cover from your old bulb. Link to comment Share on other sites More sharing options...
TrevS Posted January 21, 2007 Share Posted January 21, 2007 Hi Guys Been trying to do this today and got the plastic trim off and then unclipped the secondry surround (the bit of plastic with the letters on). However because of the massive autobox gear shifter the surround wont come off and i can just about see the bulb through the gap. So how can i get to the bulb? I tried loosening the four screws around that hold the main surround in place and noticed that there is a small connector that looks like it is connected to the bulb underneath. Which bit do i need to turn 1/4 turn anti clockwise the bulb of the connector/housing? Cheers Trev Link to comment Share on other sites More sharing options...
Sheefa Posted January 21, 2007 Share Posted January 21, 2007 Bo[[ocks. I didn't know the letters by the shifter were supposed to light up (thought it was just the lights in the rev counter. Got to go and take mine apart now. LOL Nice Rich! Mine was loose and doing the same mate. Loose connection. But when you fitted the Digi Lead for Racelogic, it worked again! Sometimes blimps off, but a little tap puts it back online! EDIT: Old, Old post for Rich! Link to comment Share on other sites More sharing options...
