uzzyuzzy Posted December 15, 2014 Share Posted December 15, 2014 Looked at the crank pulley and looks worn with a chip. Should I buy a toyota genuine part or after market and also is this something that should be fixed immediately or potentially cause greater damage. Quote Link to comment Share on other sites More sharing options...
Littler Posted December 15, 2014 Share Posted December 15, 2014 I would do the tipex test, this will confirm whether it needs immediate action. If you mark a tipex line on the 2 sections of the crank pulley and start the engine if the marks are not lining up as they were when the engine is then turned off you should get a new one. I would always go with OEM with the crank pulley, a lot of aftermarket ones do not fit (to tight on the thread etc) properly or are not dampened. That said I believe Lee @ SRD has had some good success with a certain aftermarket crank pulley but I can't remember the brand. Quote Link to comment Share on other sites More sharing options...
uzzyuzzy Posted December 15, 2014 Author Share Posted December 15, 2014 Thank you for the quick response Any idea what kind of labour costs for fitting a new one. Quote Link to comment Share on other sites More sharing options...
Littler Posted December 15, 2014 Share Posted December 15, 2014 Thank you for the quick response Any idea what kind of labour costs for such a job? I had one changed in an hour (ish) from memory but the rate is obviously garage dependant. Quote Link to comment Share on other sites More sharing options...
Nic Posted December 15, 2014 Share Posted December 15, 2014 I would fit an OEM Toyota one, part number 13407-46020 DAMPER SUB-ASSY, CRANKSHAFT http://www.mkivsupra.net/vbb/showthread.php?35945-Crankshaft-Pulley-Damper Quote Link to comment Share on other sites More sharing options...
uzzyuzzy Posted December 15, 2014 Author Share Posted December 15, 2014 Damn local toyota dealer £374 for the part. Quote Link to comment Share on other sites More sharing options...
Ric Posted December 15, 2014 Share Posted December 15, 2014 Damn local toyota dealer £374 for the part damn. 199 plus vat from TCB parts http://www.tcbparts.co.uk/ > engine > supra Quote Link to comment Share on other sites More sharing options...
