Injectors, OEM fuel Rail vs Top feed rail
Jellybean
Hey
Read a few threads and cant find the answer
Some cars are running less than 700hp
Why are some cars fitted with
  • Top Feed fuel rail and injectors as opposed to
  • Sard 800cc side feed high impedance injectors so will drop straight into the stock fuel rail without the need for a resistor pack on a Jap spec car.
What take the extra expense of the Top Feed fuel rail ? If you are going for more power , I am sure you will keep the current setup for a few years
Would you remove the Fuel pulsation damper on the Sard stock fuel rail drop Ins?
RHDJapan has a sale on for 800cc @ 350 euro for 6
Edited by Jellybean (see edit history)
Firstly sard arent the best injectors to use, out of 6 brand new i had 3 leaking fuel straight through,gave starting problems!!
Also you`re better off feeding the rail both ends, this can be done with a stock rail but again its more work,
Then when you switch to top feed it opens up a much bigger choice on injectors.
