Single turbo conversion
Guest jay0913
Guest jay0913
Hi guys,
So I'm planning to do a single turbo conversion with my n/a 5 speed supra, basically I want to do it in stages, so what's recommended to do first? Reinforcement? Etc?
The problem you have is that your gearbox won't support anything over 300lb/ft of torque for long periods. You would be better off selling your car and buying a TT auto, or ideally a 6 speed if you can afford it.
If your na was an auto, I would recommend one of DavidP 's hybrid boxes.
- - - Updated - - -
Keeping it *AND* buying a tidy auto TT will be cheaper than a properly engineered, fitted and mapped single turbo conversion of the N/A,
done to a standard that won't have you wishing you'd never got started on it. I see this all the time... Whatever you are probably thinking this
conversion will cost, I suspect you can probably quadruple.
