Littler Posted December 12, 2014 Share Posted December 12, 2014 (edited) Evening All, For anyone that has the syvecs PNP adapter harness could you take a pic and label/identify what the additional connectors are? I know these are for specific sensors, cal switches, ethernet etc but knowing exactly what is built in to the PNP harness beyond the main loom connector block would be quite useful for what I'm doing There are some pictures on Paul's site and mentions on the syvecs board but not really anything specific (happy to be corrected on this though lol). Cheers, Adam Edited December 13, 2014 by Littler (see edit history) Quote Link to comment Share on other sites More sharing options...
Littler Posted December 13, 2014 Author Share Posted December 13, 2014 (edited) Further to this with the syvecs traction control (using the ABS sensors) can I disconnect the stock TC ecu and remove everything related to the TC system on the throttle body? Can you then allow use of the stock TC off button to deactivate it? Edited December 15, 2014 by Littler (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 13, 2014 Share Posted December 13, 2014 http://www.syvecs.co.uk/forum/viewtopic.php?f=6&t=401&sid=8874c9e9567dcb96f2049acaa2a83bb8 Quote Link to comment Share on other sites More sharing options...
Littler Posted December 13, 2014 Author Share Posted December 13, 2014 Thanks, I spotted that on your thread but I couldn't see where it says the specific outputs beyond the main PnP connector block (to the OEM loom). That's still useful though and have saved that after reading it in your thread. Quote Link to comment Share on other sites More sharing options...
Littler Posted December 15, 2014 Author Share Posted December 15, 2014 Anyone else have any info on this? Quote Link to comment Share on other sites More sharing options...
markssupra Posted December 16, 2014 Share Posted December 16, 2014 I'm at exactly the same stage Adam, did you not get a small card with descriptions of the extra connectors in the box with the adapter loom? Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted December 16, 2014 Share Posted December 16, 2014 Aux Connectors: 12 Pin Connector Several Input Pins, 12V and 5V Outputs, Sensor Ground, Knock Sensor Input(2Pins) (there should be a small card with the PnP Cable where the exact Pinout is explained) 6 Pin Connector(5 Pins Available) Wideband Lambda Controller Connector Green 2 Pin Connector EGT Sensor Connector RJ45 Male Connector Connects to Laptop RJ45 Female Connector Toucan Display input/output TC Wires into the 12Pin Connector to two pins and one wire goes to the main Connector on the ECU Directly(don't remember the exact Pin now) Quote Link to comment Share on other sites More sharing options...
Littler Posted December 16, 2014 Author Share Posted December 16, 2014 (edited) Thanks all, I've spoke to Tim at JTI who makes the PnP harnesses for the syvecs and has given me similar to the above: Basically, apart from wiring up what's needed, I bring out as much spare I/O as I can on a 12 way plug (and supply the socket to go with it) along with a connector for a wideband (which we can supply), a comms socket (for dataloggers, or Toucan) and an EGT socket. In the case of the (non-auto) Supra, here's the additional I/O that's brought out: AV3, AV4, AU3, AU4, AR3, AR4, AB3, Sensor 5V out, Sensor ground, Knock Signal, Knock Ground, Power ground. Edited December 16, 2014 by Littler edit (see edit history) Quote Link to comment Share on other sites More sharing options...
Littler Posted December 16, 2014 Author Share Posted December 16, 2014 (edited) The above combined with the below should have me in good stead now http://www.syvecs.co.uk/forum/viewtopic.php?f=6&t=401&sid=8874c9e9567dcb96f2049acaa2a83bb8 Can anyone expand on what I've put here re the OEM traction control? Further to this with the syvecs traction control (using the ABS sensors) can I disconnect the stock TC ecu and remove everything related to the TC system on the throttle body? Can you then allow use of the stock TC off button to deactivate it? Edited December 16, 2014 by Littler edit (see edit history) Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted December 16, 2014 Share Posted December 16, 2014 Yes stock tc can be removed completely. You have to T off the two + wires of the rear wheel abs sensors and the+ and-of one of the front wheels. The front sensor goes to an abs converter which then connects to one of the AU inputs the two rear + wires go to the two spare AB inputs. The abs ECU is behind the radio under the spoiler ECU. Quote Link to comment Share on other sites More sharing options...
markssupra Posted December 17, 2014 Share Posted December 17, 2014 Wow, that's answered a few questions I had as well Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 17, 2014 Share Posted December 17, 2014 If anyone needs analogue to digital ABS sensor output converters I think I have a good few spare to sell. Quote Link to comment Share on other sites More sharing options...
markssupra Posted December 18, 2014 Share Posted December 18, 2014 If anyone needs analogue to digital ABS sensor output converters I think I have a good few spare to sell. I'll take one off you please Chris, how much? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 20, 2014 Share Posted December 20, 2014 £22 each, including VAT, you need one per sensor. Photos attached. Insured P&P is £6.80 by courier. Thanks. Quote Link to comment Share on other sites More sharing options...
markssupra Posted December 21, 2014 Share Posted December 21, 2014 £22 each, including VAT, you need one per sensor. Photos attached. Insured P&P is £6.80 by courier. Thanks. Sorry Chris, I'm probably getting confused here but according to Canislupus, I will only need one converter to connect to the Syvecs, front sensor to AU1(AN05) input and the two rear sensors directly to AB3 and AB4 as these are Analogue Bipolar inputs? Yes stock tc can be removed completely. You have to T off the two + wires of the rear wheel abs sensors and the+ and-of one of the front wheels. The front sensor goes to an abs converter which then connects to one of the AU inputs the two rear + wires go to the two spare AB inputs. The abs ECU is behind the radio under the spoiler ECU. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 21, 2014 Share Posted December 21, 2014 Is this for ABS and TC, or just traction control? I was assuming ABS as well where you do need to monitor each wheel speed independently. I am thinking it must be solely for TC then? I think you need to ask Ryan or Syvecs, these converters take one input each. So I guess you need to convert one front analogue out from the wheel speed sensor to digital for the spare input, as you have no spare analogue inputs? is the Syvecs not doing ABS then? Quote Link to comment Share on other sites More sharing options...
markssupra Posted December 21, 2014 Share Posted December 21, 2014 Is this for ABS and TC, or just traction control? I was assuming ABS as well where you do need to monitor each wheel speed independently. I am thinking it must be solely for TC then? I think you need to ask Ryan or Syvecs, these converters take one input each. So I guess you need to convert one front analogue out from the wheel speed sensor to digital for the spare input, as you have no spare analogue inputs? is the Syvecs not doing ABS then? I far as I know the Syvecs only controls the TC as I was talking to Tim at JTI on Friday. I was hoping to still run the ABS through the stock ABS ECU. Looks like I will need at least one of your converters. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 21, 2014 Share Posted December 21, 2014 Well, I have plenty, maybe you'd like a spare, too ? Quote Link to comment Share on other sites More sharing options...
markssupra Posted December 21, 2014 Share Posted December 21, 2014 Cheers Chris, I have your bank details and will do a transfer later if that's OK? Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted December 21, 2014 Share Posted December 21, 2014 Syvecs only controls the tc. You just need 1 front input for that. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 22, 2014 Share Posted December 22, 2014 This post of mine may be of interest: http://www.mkivsupra.net/vbb/showthread.php?316889-Traction-Control-and-ABS-analogue-to-digital-converters&p=3969089#post3969089 Quote Link to comment Share on other sites More sharing options...
