lexmk4 Posted December 10, 2014 Share Posted December 10, 2014 Hi guys, Got a question about the abs. I'm not looking to delete the abs but would like to relokate it to the trunk. Doing that means i have to make the front lines longer. Would there be any reason why that would be a problem? Cause of it being a clossed system i would say that distances wouldn't really matter? Thx for the help Link to comment Share on other sites More sharing options...
markssupra Posted December 10, 2014 Share Posted December 10, 2014 Not just the brake lines would have to be made longer, also the wiring and relays would have to be moved. I have done this, but my car is not finished yet so the ABS is not tested! The brakes do actually work though. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 10, 2014 Share Posted December 10, 2014 As fluid is (all but) solid, from a compression point of view, the system will actuate, and I can't see the line length affecting the latency of the pulsing of the fluid, as you are only lengthening the front lines, but shortening the rear. Can't see an issue, if you want to move it. Just curious as to WHY you want to move it, if you don't mind me asking? Link to comment Share on other sites More sharing options...
Ian C Posted December 10, 2014 Share Posted December 10, 2014 £10 says it's for "better weight distribution" £100 says even Lewis Hamilton wouldn't be able to tell the difference Link to comment Share on other sites More sharing options...
ManwithSupra Posted December 10, 2014 Share Posted December 10, 2014 £10 says it's for "better weight distribution" £100 says even Lewis Hamilton wouldn't be able to tell the difference I reckon its for an engine bay tuck. Link to comment Share on other sites More sharing options...
lexmk4 Posted December 10, 2014 Author Share Posted December 10, 2014 Thx guys. This is very helpful. And to answer the question. I'm going 1uz twins and would like some more room. And yes also to clean the bay. Awesome guys Link to comment Share on other sites More sharing options...
Ian C Posted December 10, 2014 Share Posted December 10, 2014 Moving it in order to fit in a massive V8 and turbos is Link to comment Share on other sites More sharing options...
