new radiator with 2x elektric fans
jza800
I have purchased this new radiator to my car, is that a good setup to my engine, my engine is stock 2jzgte twin turbo, with a Little raised boost... have heard horror stories about elektric fans, but also good stories...'
so what experience do you have with this setup???
42mm Core aluminum racing radiator
Our products are 100 % Brand New
100% quality assurance tested
Great cooling capacity, twin water channel core design
Up to 65% reduction in engine temperatures
Specification:
Core Size: 700 x 400 x 42
Inlet/Outlet Dia : 35
nothing on the fans unfortunately
Imo it's either stock fan and shroud or srd electric fan kit. No other fans will cut it. It will work yes but I doubt you would see an improvement over stock.
Also I may be mistaken but I think connecting it to the auxiliary fan wiring you were referring to only switches on when air con is turned on?
i dont wanna see a improvenment over stock, just what to have the the same cooling as i had the stock fan on the pump.. and as i like the clean look i will get, by removing the stock fan...
the Little fan i have on mine, dont turn on when i activate the a/c, only when the engine temp goes up.. and it have a sensor in the radiator, and only what to fit the signal wire to the plug, the rest off the power will come direkt from the battery, to a reley...
The aux fan comes on with the ac if needed but also if the water temp goes above 97 degrees so yes you can use it to active the fans
The things a total abortion. Just think about it. You are hammering it up an incline at 50 MPH, and at that speed ram air effect should be more than sufficient to make fans needless. But the "designer" has an aluminium plate sealing the engine side of the rad, reducing ram air flow through the core to a ludicrous extent. The close mesh design of the fan supports, and the close bladed fans themselves, further limit "free" (as in needing no energy to drive fans), air flow. The fans themselves, at 120 Watts, are pitiful, and wouldn't cool a Duchess having a fit of the vapours. I would reckon the stock, engine driven fan would be approaching a 1000 Watts when the viscous coupling sees a high temperature. The thing's a bad joke. Plus if you have an automatic transmission you have no bottom tank heat exchanger, remember the heat exchanger warms the auto box oil quickly in cold start situations, then exchanges excess transmission temperatures into the water to air heat exchanger (radiator). Car makers DO know about this stuff, and you bin it only after due forethought.
i can see that the stock Shroud also close alot off the stock radiator... i would like to have the elektric fans on the car, but if it is a bad thing, i have to keep the stock fan, and put the stock Shroud over on the aluminium radiator... :(
- - - Updated - - -
Also bear in mind that the stock fans produces 3,300 CFM of air. What does the ebay fan's produce?
i have no idea, the seller you sent me that infoes i have postet..
The stock shroud is no where near as close to the rad though.
It allows the air to flow through the rad at high speed
This is the reason our fan kit doesn't have a shroud.
It uses 2 14" fans that have the power to pull the air through the rad, without relying on a shroud.
- - - Updated - - -
