AC Delete
r0cknr0lla
Hey Guys...
Can't seem to find the 100% spot on answer within the threads.. Whilst deleting the AC system. Must one Block the pipes leading from bulkhead to the Matrix or can I simply remove them completely. If possible to delete completely.. how do you get these pipes out from the matrix system as I can't seem to get the unit open. I have managed to slide the Evaporator out but the pipes don't look as easy as that.
Must one go as far as chopping them??
Pls help!
I removed the pipes (which are conected to a small rad inside the matrix), by opening the matrix cover, its a white cover on the passenger side which clips off, the little radiator looking thing is behind it, you obviously need the dash out to do this though.
it doesnt weigh much so if your dash is in place i wouldnt bother
