Hot front brake disc
Samsar
Morning all,
I use my car as daily and on the way home from work last night the car didn't seem right. Something made me think I had a puncture on the N/S/F.
I got out and had a look and all was fine so I checked the disc and my god it was hot and I mean really hot. I checked the O/S/F and that was warm but nothing like the other side.
My question is what would cause this? I've already got some new discs and pads in my garage ready to go on the front but could it be something else causing that disc to get redders?
When my callipers were sticking I had them freed up and they started again. Iirc you either need to refurb them or replace as if they stick on your new set the heat generated will just knacker the new set, of pads and discs faster.
When my caliper was sticking I also got juddering and noise at around 90(ish) on a private track.
Before you take my word as being right for the love of god wait for someone else more knowledgeable to come along first and give their input :D
I'd just been testing on my private track at about that speed too 😉
Refurb properly or buy new, freeing them off is a waste of time as they will sooner or later seize up again
What calipers do you have, 2 piston j specs or 4 piston UK spec ?
It would pay you to have a close look at all four calipers, at the minimum get them refurbed by Big Red or similar
brake refurb specialist.
At the very least do both fronts !!
Also check the brake lines and when you do the calipers it would pay to replace the brake
fluid in the whole system at the same time, easy enough to do and brake fluid
is pretty cheap, you'd only need 1-2 litres max
Very in my opinion, needs fixing asap like yesterday
It could be the carrier seizing on the sliding pins if its a j spec caliper, or it could
be the piston/s also seizing get it looked at if you don't know what to do, pretty
simple for any decent mechanic to deal with.
Not worth doing it yourself in my opinion unless you know what your doing
and have the tools to do the job properly, for what the refurb comps do it
for i wouldn't mess around with them
Have a search on here as a few members have used the refurb comps and were
very happy with the job done etc
http://www.biggred.co.uk
Why did I know you'd say that
I'll have to get someone to do it because I'm bloody useless at mechanics.
Cheers for your help guys
If your useless with mechanics then yes get someone who knows what their doing
to check them out for you, it would make sense to do all four as they will all be in a
very similar condition.
Either could be the cause, you can free sticking slider pins and re grease using high temperature molybdenum based grease. A sticking piston(s) in the caliper mean it needs a strip and rebuild, not for the feint hearted. I supply stainless steel pistons and also seal kits if you decide and once and for all fix of your existing calipers. If the caliper piston(s) are seized it's almost certain the chrome on the pistons has broken down and just cleaning and re using them will just be a short term fix.
I took the wheel off and had a look to see what's what. I rang Keron to see if he had any refurbed calipers in stock and he also said it might just be the slider pins. Had another look and decided I didn't have a clue so put the wheel back on and parked it up😂
My dad came over and we chatted about s**t and then my neighbour came home from work and we started talking a bout his Porsche he's got locked in his garage.
Oh well tomorrow is another day and I'll get it looked at by someone that knows what they're looking at 😉
When I had mine freed up the opposite side seized up a few weeks later. Maybe you could get it/them freed up, but if I was you I would be sourcing some more afterwards quite quickly.
HI Mate. do you wont me to have a look. sat or sunday. but if they need a rebuild id need a kit. or could just have a look and see whats up. speek to MR WILSON. about the kit, or did you move from kent .
Hi buddy, nope still in Kent (Trashford). I'm going to see if I can get someone to come around tomorrow and have a gander at them and see what's what. If I get no joy your offer of coming down would be much appreciated.
Can I let you know tomorrow how I get on and we'll go from there?
Just pop the wheel off and then undo the bottom bolt on the brake caliper. Flip the caliper up and see if the bit you just flipped up slides in and out freely on it's pivot. Then grab hold of the bottom slider (that the bolt you've just removed screws into - will have a flexible rubber sleeve covering it...) and see if that pushes in and out easily. If both sliders move, it's the caliper.
