dangerous brain Posted December 3, 2014 Share Posted December 3, 2014 Is it a big issue to use a VVTi TT engine and box to convert an NA aerotop to TT? Would a VVTi instrument cluster get around the clocks difference? What else would be an issue? Link to comment Share on other sites More sharing options...
CanisLupus Posted December 4, 2014 Share Posted December 4, 2014 You'd need the VVTI ECU and wiring harness if the engine is complete with all sensors. Cluster maybe too. Other than that i can't think of any problems right now. Link to comment Share on other sites More sharing options...
The Raven Posted December 4, 2014 Share Posted December 4, 2014 I dont know how the dash loom would react to the ECU from a facelift as the dials are different? Link to comment Share on other sites More sharing options...
keron Posted December 4, 2014 Share Posted December 4, 2014 the dash board and panels are different as well as the wiring. the prefacelift dash and clocks will work with the vvti, just need to do a mod to the rev counter. is it auto or manual or you want to do the tiptronic conversion? Link to comment Share on other sites More sharing options...
dangerous brain Posted December 4, 2014 Author Share Posted December 4, 2014 Added complication being it is an aristo engine. I would get the entire lump and box with ECU and the bits I need. All I would need is a way of driving a speedo or a replacement speedo I think? Link to comment Share on other sites More sharing options...
Abz Posted December 4, 2014 Share Posted December 4, 2014 the dash board and panels are different as well as the wiring. the prefacelift dash and clocks will work with the vvti, just need to do a mod to the rev counter. is it auto or manual or you want to do the tiptronic conversion? This, Keron did the mod on mine to get the rev counter working (though I already had facelift dash & clocks in). Link to comment Share on other sites More sharing options...
