sidewaysdan Posted December 3, 2014 Share Posted December 3, 2014 Anybody had a similar problem. The blower seems to work when it wants realy, if I put the blower on full nothing happens it just stays low speed doesn't speed up, Any advice would be great. Thanks Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted December 3, 2014 Share Posted December 3, 2014 If you press ac or any other buttons nothing happens? Quote Link to comment Share on other sites More sharing options...
Scott Posted December 3, 2014 Share Posted December 3, 2014 Sounds like the control board is starting to get some dry solder joints. Happens from time to time. I would pick up a spare, generally £15, and see if that sorts it. You'll always be able to move it on Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted December 4, 2014 Author Share Posted December 4, 2014 If you press ac or any other buttons nothing happens? Nothing, just stays at one speed. Low. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted March 1, 2015 Author Share Posted March 1, 2015 Ok update time. So I changed the heater controll unit with another and still the same. is it likely it's the actual blower/fan unit itself, is this a common problem. Cheers for any advice Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 1, 2015 Share Posted March 1, 2015 I had a spare heater system laying around and dissembled it recently so I've got one of everything from it, if you need any bits lemme know. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted March 1, 2015 Author Share Posted March 1, 2015 Is that the fan behind glovebox? Cheers Quote Link to comment Share on other sites More sharing options...
Scott Posted March 1, 2015 Share Posted March 1, 2015 The fan is the heater matrix assembly. Full dash off to replace it. Quote Link to comment Share on other sites More sharing options...
heckler Posted March 2, 2015 Share Posted March 2, 2015 dont discount the wiring and ecu Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted March 2, 2015 Author Share Posted March 2, 2015 Oh great.. More fun for me then Quote Link to comment Share on other sites More sharing options...
Scott Posted August 18, 2016 Share Posted August 18, 2016 Did you ever get to the bottom of this? I have a feeling it's the little box on top of the stereo but I can't be sure. Mine is now presenting the same problem after recently fitting an oil pressure/temperature gauge. I have a feeling I've pulled on a harness somewhere. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted August 19, 2016 Author Share Posted August 19, 2016 I didn't mate . Haven't really used the car this year but I will look into it again when I get a chance . Quote Link to comment Share on other sites More sharing options...
