Scooter Posted December 4, 2014 Share Posted December 4, 2014 Ta for that Chris, always wondered about the natural state of things... Quote Link to comment Share on other sites More sharing options...
fastby4 Posted December 5, 2014 Share Posted December 5, 2014 In many cases of this problem is that the oil seal spring jumped down. Thomas Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 5, 2014 Share Posted December 5, 2014 The spring only gets displaced as a result of the oil pressure behind the seal. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 5, 2014 Share Posted December 5, 2014 People say and think this, but in all the cases I have seen the spring has "jumped off" during removal of the old seal, and would have been in place until it was levered out. IMO. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted December 5, 2014 Author Share Posted December 5, 2014 Well time will tell see how it goes after a drive Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 5, 2014 Share Posted December 5, 2014 People say and think this, but in all the cases I have seen the spring has "jumped off" during removal of the old seal, and would have been in place until it was levered out. IMO. Mine was off when the seal failed the second time as I just removed the pump complete with seal, and the spring was floating about when I dismantled the pump, I think the pressure forces the seal lips outward and dislodges the spring. Quote Link to comment Share on other sites More sharing options...
fastby4 Posted December 5, 2014 Share Posted December 5, 2014 I use a another seal ring. The same manufacturer as OEM Toyota but slightly larger in diameter. On the back I fix the spring with silicone. That works very well. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 5, 2014 Share Posted December 5, 2014 Better to fix the cause not the symptom. Quote Link to comment Share on other sites More sharing options...
jjs_82 Posted December 6, 2014 Share Posted December 6, 2014 What if that silicone comes away from the seal? Could be bad. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 6, 2014 Share Posted December 6, 2014 What if that silicone comes away from the seal? Could be bad. Although unlikely, it could block the drain and compound the original problem, but if the oil pump is worn and leaking it will not prevent the seal from being displaced. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted December 6, 2014 Author Share Posted December 6, 2014 Well so far so good left a sheet under it see if anything happens over nite Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 6, 2014 Share Posted December 6, 2014 Well so far so good left a sheet under it see if anything happens over nite Be wary when driving it,especially at high RPM, keep an eye on the low oil light, as this was the only think that alerted me to the problem, I had lost 60% of my oil before I realised, but I was lucky. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted December 6, 2014 Author Share Posted December 6, 2014 Will do rick thanks Quote Link to comment Share on other sites More sharing options...
