Other parts to change when changing clutch?
James
I've just bought an HKS LA twin plate clutch as my current clutch is slipping a lot. I'm just curious as to which other parts I should be replacing while the clutch is being changed?
The HKS page for the clutch suggests the following as required and not re-usable:
  • 8x Flywheel bolt
  • Clutch release hub snap ring
  • Clutch Release bearing shaft snap ring
  • Input shaft bearing
With the following as also required:
  • Release bearing
  • Clutch Release bearing washer
  • Clutch Release bearing wave washer
  • Clutch thrust cone spring washer
  • Clutch Release bearing hub
Having not had a clutch changed before, can anyone advise what bits I should be going for?
Thanks very much! :thumbs:
