Heater fuse blows
JohnHorner
You will have to just start disconnecting things until you isolate the part of the circuit with the ground fault or whatever is causing it. Time and patience needed, and a wiring diagram! I wou;d use a very good quality ohmeter between ground and the circuit side of the fuse holder, with no fuse fitted, to save on blowing dozens of fuses. It may need to resolve very low ohms to work effectively. Possibly a job for a good auto electrician if the fault doesn't show itself easily.
