esskiboy Posted November 24, 2014 Share Posted November 24, 2014 Afternoon Just after some thoughts re the CT results 165 160 150 165 165 155 3 & 6 are are bit lower than the others. Doesnt seem to disastrous to me. Your thoughts pls. Thanks Quote Link to comment Share on other sites More sharing options...
Kaan W Posted November 24, 2014 Share Posted November 24, 2014 Looks ok to me, I think 130psi is the minimum you would want or more than 10% difference between cylinders. Quote Link to comment Share on other sites More sharing options...
mellonman Posted November 24, 2014 Share Posted November 24, 2014 yeah look alright to me too Quote Link to comment Share on other sites More sharing options...
Kaan W Posted November 24, 2014 Share Posted November 24, 2014 Just found this - http://www.mkivsupra.net/vbb/showthread.php?231848-Compression-Test&highlight=compression+test Quote Link to comment Share on other sites More sharing options...
Nic Posted November 24, 2014 Share Posted November 24, 2014 See 'Engine Mechanical' link here, it details the compression test result. http://www.mkivsupra.net/vbb/content.php?51-Repair-Manuals Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 24, 2014 Share Posted November 24, 2014 Did you do the test with the throttle held wide open bud? I done mine a few weeks ago, before going single, and I had almost exactly 180 psi on all 6 cylinders Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 24, 2014 Share Posted November 24, 2014 Do a leak down test after running it up to temp. It's a lot more meaningful than a basic compression test. Quote Link to comment Share on other sites More sharing options...
esskiboy Posted December 12, 2014 Author Share Posted December 12, 2014 25% across the board. Thoughts please. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 12, 2014 Share Posted December 12, 2014 The figures you posted earlier look OK to me. Quote Link to comment Share on other sites More sharing options...
esskiboy Posted December 13, 2014 Author Share Posted December 13, 2014 The figures you posted earlier look OK to me. Chris -the most recent figures are for the leak down. Not sure if that is what you where referring to. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 13, 2014 Share Posted December 13, 2014 25% leakdown is poor, but i suspect as they are all even (I presume you mean all 4 cylinders showed 25% leakage?), you have not domne it correctly. Are you sure the test was valid on a warm engine as quickly as possible after shut down, with the throttle held open? I can get F3 engines down to less than 2% (but not for long, one race sees them around 3 to 4%). A fresh road car engine should do 5 to 10% pretty easily. Quote Link to comment Share on other sites More sharing options...
