jza800 Posted November 22, 2014 Share Posted November 22, 2014 I got some eu/us spec camshafts and thinking about to put it in my j-spec engine, but have read that Less aggressive camshafts allow the engine to respond faster. so my question is. should i keep my j-spec cams to keep the engine to respond faster, or should i put the eu cams in??? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 22, 2014 Share Posted November 22, 2014 Unless you have a mappable ecu to optimize the map to suit the new valve timing I would leave things be. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 22, 2014 Share Posted November 22, 2014 I got some eu/us spec camshafts and thinking about to put it in my j-spec engine J-spec and UK/US/Euro spec exhaust camshafts are identical, it is only the intake cams that have different duration/lift. Quote Link to comment Share on other sites More sharing options...
jza800 Posted November 22, 2014 Author Share Posted November 22, 2014 yes i now that.. i just think that i could give me a Little mere fuel= more power.. but regards to chris it is not enough, as i need another ecu... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 22, 2014 Share Posted November 22, 2014 You may as well go for 256 cams if you change at all, whilst a stock ecu will allow them to run OK, the map will far from optimal. Quote Link to comment Share on other sites More sharing options...
