using too much fuel or?
Guest Pricer69
Guest Pricer69
hey guys
just a quick question, how much fuel do you guys use per week lol? i got a 3.0 N/A with double decat and race manifold that i got from the US. im using like £60 and that gets me 240-250 miles, sometimes if that, i hardly ever change above 3k. i havent got a clue if thats good or not lol was hoping someone could help me out :)
cheers
I've been wondering the same thing, last time I filled up from near empty I went 275 miles before needing to refuel, with a mix of fast motorway / city driving. Even though it's a 3.0, I'm sure it can do a little more.
From what I understand, as a start make sure you don't have any exhaust leaks and give the o2 sensors a check (there is a guide for it somewhere on the forum)
02 sensors are probably black as anything.
Get some new ones from http://www.rockauto.com, that's cheap enough,
A good service and it should be sorted.
What fuel are you using?
Get some new ones from www.rockauto.com, that's cheap enough,
Ah thanks for the link, was wondering where cheaper ones could be found. Will get a new pair and report back to see if it makes any difference.
Usually just use 95 most of the time, only go 97 for longer drives.
I did a regular 100 mile trip twice per month when I had the 3.0 motor in and it cost me £60 (200 miles=£60). Cleaned my 02 sensors in lemon juice and it made no noticeable difference.
They could of been goosed.
I did every trick to clean and get more, nothing.
Brand new 02 sensors and it was like driving a different care
I used Tesco 99 and got over 300 a tank, and once a month shell v power nitro to give it a good clean internally
