ellis Posted November 25, 2014 Author Share Posted November 25, 2014 Best to actually phone Keron. I am just thinking of your issue. for the ECU to "know" there's an issue with the solenoid it must see a short or open on the driver output. Whilst I suppose the driver transistor itself could be the issue i would have thought something external to the ABS ecu would be the cause. Disconnect the ecu plug and the solenoid plug and check for shorts to ground or open circuit between the connector to the ECU and the solenoid itself. Interesting problem Keron's on the case! I'll pass that on to the engineers - cheers Chris. Link to comment Share on other sites More sharing options...
Burna Posted November 25, 2014 Share Posted November 25, 2014 I didn't get an answer before, but I'll ask again, have you got RLTC fitted Ellis? Link to comment Share on other sites More sharing options...
ellis Posted November 25, 2014 Author Share Posted November 25, 2014 No mate, just the useless 'Let's Try and Kill You as You Pull Out of a Junction' standard fit TC! Link to comment Share on other sites More sharing options...
Burna Posted November 25, 2014 Share Posted November 25, 2014 No mate, just the useless 'Let's Try and Kill You as You Pull Out of a Junction' standard fit TC! The reason I asked is because I had the exact same thing, but because I have RLTC the car would hardly drive as it wasn't getting a signal from the broken ABS sensor, and would send the RLTC into a fit and harsh cut the injectors. As soon as I turned off the RLTC the car would drive exactly like yours. I'll bet a beer its a broken ABS sensor. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 25, 2014 Share Posted November 25, 2014 His car is stock in that regard, no RLTC fitted. The stock ABS ecu does (or at least *should*) indicate no wheel speed sensor signal by means of a code, and apparently it's not doing that. Good call though. Link to comment Share on other sites More sharing options...
Burna Posted November 25, 2014 Share Posted November 25, 2014 His car is stock in that regard, no RLTC fitted. The stock ABS ecu does (or at least *should*) indicate no wheel speed sensor signal by means of a code, and apparently it's not doing that. Good call though. Aaah good point about the error code, I'm sure I ascertained which wheel sensor was faulty by the code, it was a long time ago :/ Link to comment Share on other sites More sharing options...
natony Posted November 25, 2014 Share Posted November 25, 2014 This is what I'm after. 89541-14060 Weird thing is, that second part number with the NR links to a wiper motor for the JZA70!! What's that all about! http://i289.photobucket.com/albums/ll206/ellisgrange/ABSECU1_zpse50c9d8c.jpg I've got 2 of these if you still need one Link to comment Share on other sites More sharing options...
Slam Posted November 25, 2014 Share Posted November 25, 2014 Aaah good point about the error code, I'm sure I ascertained which wheel sensor was faulty by the code, it was a long time ago :/ You owe him a beer mate Link to comment Share on other sites More sharing options...
Burna Posted November 25, 2014 Share Posted November 25, 2014 You owe him a beer mate It isn't fixed yet, and my money is still on a corroded wheel sensor Link to comment Share on other sites More sharing options...
bignum Posted November 25, 2014 Share Posted November 25, 2014 I have an intermittent abs fault, can i check fault codes even though i`m not running a stock main ecu? Link to comment Share on other sites More sharing options...
ellis Posted November 26, 2014 Author Share Posted November 26, 2014 I've got 2 of these if you still need one Darn, didn't notice this until now - just paid for one!! Link to comment Share on other sites More sharing options...
wile e coyote Posted November 26, 2014 Share Posted November 26, 2014 These cars are getting to that age now Ide be replacing all as soon as one fails Link to comment Share on other sites More sharing options...
ellis Posted November 26, 2014 Author Share Posted November 26, 2014 OK some progress but we need some advice/help from the techies. The engineers have run a wire from the ABS pump back to the ECU which takes away the problem completely. There is a yellow and green wire signal wire running from the ABS pump back to the ECU which obviously has a break in it somewhere but the guys can't find exactly where it runs to in the loom. Anybody know where this would run to? Any multi-plugs where it could be apart/split etc? We're almost there! They could run a wire directly bypassing the faulty wire but would very much like to trace the problem properly and find where this wire has split or failed. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 26, 2014 Share Posted November 26, 2014 (edited) Just properly splice in the new wire with glue sealed Raychem crimps and be done with it. That's my advice. Chasing down thge plug and socket or whatever at fault, id'ing the correct terminals and sourcing them, splicing them in, blah blah. Time is money and it sounds like it's eaten plenty of both. Just tape the new wire to the loom and be done with it! BTW, I *THINK* this goes to a connector up and to the left of the engine ecu in the LH foot well, but far from certain on that. You could separate, contact cleaner spray, and re-connect all the plugs and sockets down there, but then you might ~#$@ something else up in the process Edited November 26, 2014 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
ellis Posted November 26, 2014 Author Share Posted November 26, 2014 Just properly splice in the new wire with glue sealed Raychem crimps and be done with it. That's my advice. Chasing down thge plug and socket or whatever at fault, id'ing the correct terminals and sourcing them, splicing them in, blah blah. Time is money and it sounds like it's eaten plenty of both. Just tape the new wire to the loom and be done with it! BTW, I *THINK* this goes to a connector up and to the left of the engine ecu in the LH foot well, but far from certain on that. You could separate, contact cleaner spray, and re-connect all the plugs and sockets down there, but then you might ~#$@ something else up in the process Cheers Chris - have passed that on. It's a bit of a maze with the wiring loom and I think even they are readying the Raychems as we speak! If anybody knows exactly where it goes, great, if not, it's getting spliced!! Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 26, 2014 Share Posted November 26, 2014 I can e-mail you the full car wiring diagram set for the J-Spec cars, but here's a bit that's most relevant Link to comment Share on other sites More sharing options...
ellis Posted November 26, 2014 Author Share Posted November 26, 2014 I can e-mail you the full car wiring diagram set for the J-Spec cars, but here's a bit that's most relevant Thank you Chris - that would be really useful if you could/have the time - I can print it out and take it round to them - cheers. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 26, 2014 Share Posted November 26, 2014 E-mail sent, it's got about 5 minutes to go before it's on my server. Link to comment Share on other sites More sharing options...
ScottC Posted November 26, 2014 Share Posted November 26, 2014 The wiring diagram in the PDF I sent you not good enough then? Link to comment Share on other sites More sharing options...
ellis Posted November 26, 2014 Author Share Posted November 26, 2014 The wiring diagram in the PDF I sent you not good enough then? Don't be so ruddy sensitive woman!! Yours was lovely x Link to comment Share on other sites More sharing options...
ellis Posted November 27, 2014 Author Share Posted November 27, 2014 Well the broken wire has been traced to the engine bay and that's about as far as it goes now. Now wire spliced in to bypass the last remaining bit and the light is off. MoT now passed and car can be collected tomorrow. A frustrating episode but hardly life-threatening. Next will be tackling why the O/D light and Slip Cont Off lights are still flashing merrrily! So if anybody has ideas on that one, let me know! Speed delimiter sounds to be the issue but am not sure. Link to comment Share on other sites More sharing options...
Benjy Posted November 27, 2014 Share Posted November 27, 2014 If you find out why the OD light is flashing, let me know... Lol Link to comment Share on other sites More sharing options...
wile e coyote Posted November 27, 2014 Share Posted November 27, 2014 Is it not showing any codes ? Link to comment Share on other sites More sharing options...
ellis Posted November 27, 2014 Author Share Posted November 27, 2014 No codes showing any more which leads me to believe that the kmh - mph sensor is the culprit based on my inferior and sadly lacking knowledge of all things Link to comment Share on other sites More sharing options...
Slam Posted November 27, 2014 Share Posted November 27, 2014 Burns owes you a pint Glad you got that one sorted out. There is a thread here about o/d light flashing , sure slip light was mentioned at some point. Link to comment Share on other sites More sharing options...
