supra_ufo Posted November 19, 2014 Share Posted November 19, 2014 Afternoon folks I have a set of hub centric 20mm wheel spacers however they do not include the studs, so rather than spending £80+ish pound on a set of ones with studs is it possible to buy this... http://www.ebay.co.uk/itm/110788770473?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT the main question is will it work on the rears (advertised for front wheels) and will I have enough room to get them in? The other option is this however the engine code doesnt match mine http://www.ebay.co.uk/itm/JZZ30-Soarer-1JZ-GTE-10-x-Longer-Rear-Wheel-Studs-65mm-/110600963782?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item19c054c6c6 Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 19, 2014 Share Posted November 19, 2014 I bought mine from demon tweeks, found them cheaper than anywhere else. Think they were listed for a vauxhall, but they share the same spline pattern Quote Link to comment Share on other sites More sharing options...
jagman Posted November 19, 2014 Share Posted November 19, 2014 Often the studs offered are wrong - they have the wrong shank taper , you can pull them in but use too much force to do so - this over stresses the studs - close but not carling Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 19, 2014 Share Posted November 19, 2014 That's what I found with the ones I bought off eBay. However, the demon tweeks ones were perfect. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted November 20, 2014 Author Share Posted November 20, 2014 Link please Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted November 20, 2014 Share Posted November 20, 2014 I have H&R on mine Quote Link to comment Share on other sites More sharing options...
r0cknr0lla Posted November 20, 2014 Share Posted November 20, 2014 Yeah.. link please Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted November 25, 2014 Author Share Posted November 25, 2014 Gaz? Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 25, 2014 Share Posted November 25, 2014 Sorry chaps, forgot about this. I'll have a look tonight, to see if I can find them again! Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 25, 2014 Share Posted November 25, 2014 pretty sure it was these ones http://www.demon-tweeks.co.uk/performance/wheel-nuts-bolts/grayston-wheel-stud m12 x 1.5mm vauxhall From memory, stock studs are 44mm, so you have the choice of 7mm or 19mm longer I'm almost certain these were the correct type, but if you do order them, please double check first - comparing one to a stock one before fitting Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted November 25, 2014 Author Share Posted November 25, 2014 thanks gaz Wish my car was with me so I can check, im pretty sure our wheels were very similar, mine are ruff racing 9.5" ET35. As an example I have 20mm spacers so if I were to go for the 7mm then the nut wont have enough thread, so i'll play it safe with 19mm longer. hows your build going? please update... Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 25, 2014 Share Posted November 25, 2014 My build is done bud, running beautifully Next spring is tidy up the paintwork, and find something else to modify lol ! I've also got 9.5 rears, et35 from memory, but I found they rubbed when I tried 15mm spacers I think 10mm would be the limit without arch work, but I am about 35mm lower than stock on teins. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted November 25, 2014 Author Share Posted November 25, 2014 My build is done bud, running beautifully Next spring is tidy up the paintwork, and find something else to modify lol ! I've also got 9.5 rears, et35 from memory, but I found they rubbed when I tried 15mm spacers I think 10mm would be the limit without arch work, but I am about 35mm lower than stock on teins. You need to update the project mate as I may go down the same route in the coming years. From what I can see there wont be much rubbing as im not running that low on the rears Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 25, 2014 Share Posted November 25, 2014 See here buddy, my results are near the end ^http://www.mkivsupra.net/vbb/showthread.php?t=313334^ Gaz's single build Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 25, 2014 Share Posted November 25, 2014 You may be ok with your ride height, be interested to know how you get on Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted November 25, 2014 Author Share Posted November 25, 2014 ill update my build thread, currently looks like this though so defo in need of spacers Quote Link to comment Share on other sites More sharing options...
Ric Posted November 26, 2014 Share Posted November 26, 2014 did you have the arches rolled before the paint? i can't remember, if you bring the wheels out they might scrub? if not Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted November 26, 2014 Author Share Posted November 26, 2014 No I didnt Ric, suppose if it comes to it I have a few options, either run stretch tyres or get it rolled. Quote Link to comment Share on other sites More sharing options...
Ric Posted November 26, 2014 Share Posted November 26, 2014 rolling can crack paint though, just so you know Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted November 26, 2014 Author Share Posted November 26, 2014 im pretty sure I PM'ed Al Massey months ago and he said it cant... Quote Link to comment Share on other sites More sharing options...
Ric Posted November 26, 2014 Share Posted November 26, 2014 im pretty sure I PM'ed Al Massey months ago and he said it cant... Arch enemy did mine, and it cracked, all properly done, heated etc. didn't matter so much as it was been painted. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted November 26, 2014 Author Share Posted November 26, 2014 Ill see, im pretty sure Al was trained by them too, if there is a risk of it cracking id rather go stretched tyres. Ill ask the bodyshop and see if they can roll it before its painted again. Quote Link to comment Share on other sites More sharing options...
