Jellybean Posted November 13, 2014 Share Posted November 13, 2014 The weather last two days here is just constant down pours and flooding When moved the next morning at 10km/h she gives off a high pitched squeak with the rotation of the wheel until I get out of the car park , park her up and nothing , seems to happen when she is left to sit over night I am nearly sure I heard the same noise from a new 2014 golf yesterday in the car park I presume weather related ? Quote Link to comment Share on other sites More sharing options...
trebor69 Posted November 13, 2014 Share Posted November 13, 2014 Maybe overnight corrosion on the discs from all the water .....also sounds like your calipers may be starting to tighten up/stick... Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 13, 2014 Author Share Posted November 13, 2014 Cool! Rain over here is crazy! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 15, 2014 Share Posted November 15, 2014 Seizing rear caliper piston or pistons, if UK spec brakes. Seizing rear caliper piston or caliper slider pins if Jap spec sound likely from your description. See if a rear wheel is getting hotter than the other after a mainly braking free run. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 15, 2014 Author Share Posted November 15, 2014 Thanks! They are UK brakes, will test the wheel temp But just re-built all the calipers a few months back with your SS pins Chris LOL, the squeak disappeared until last night , seems to have a small squeak when I turn right at very low speed 5km/hr need to try replicate it again today , wheel bearing? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 15, 2014 Share Posted November 15, 2014 Yes, could be a failed bearing, once they spin on the hub flange they can squeak and squeal. See if the hub nut is REALLY tight, if the hub flange is worn the nut usually slackens off. Tightening it is NOT a fix though. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 15, 2014 Author Share Posted November 15, 2014 handbrake shoes were also replaced in July , I have done alot of miles in the last month , maybe thats a factor Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 15, 2014 Author Share Posted November 15, 2014 Yes, could be a failed bearing, once they spin on the hub flange they can squeak and squeal. See if the hub nut is REALLY tight, if the hub flange is worn the nut usually slackens off. Tightening it is NOT a fix though. thanks , sounds like I need to get her up on a ramp and do the usual pulling and blinding , thanks Chris! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 15, 2014 Share Posted November 15, 2014 Make sure the handbrake is OFF and ideally the pads out before doing the pulling and tugging. The handbrake will stabilize the hub bearing if it's ON. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 15, 2014 Author Share Posted November 15, 2014 thanks Chris! Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 15, 2014 Author Share Posted November 15, 2014 All four break discs are equally as warm after 5km , Luke warm , easy to touch by hand Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 22, 2014 Author Share Posted November 22, 2014 Handbrake Shoes were changed recently , few hundred ago Video 1: https://www.youtube.com/watch?v=Vthz7dNN7y0&list=UUhxucTH_MIG4f6VVm-j1pcQ with the Handbrake ON squeaks when rotated in the forward direction ( as if the car was being driven forward) No squeak when the rotation is in the rear direction ( as if the car was in reverse ) Creaking on pulling and pushing the wheel Video 2: https://www.youtube.com/watch?v=SM3Ad22yIiY&list=UUhxucTH_MIG4f6VVm-j1pcQ with the Handbrake OFF squeaks when rotated in the forward direction ( as if the car was being driven forward) No squeak when the rotation is in the rear direction ( as if the car was in reverse ) Creaking on pulling and pushing the wheel Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 17, 2014 Author Share Posted December 17, 2014 Just to update the cause , the handbrake shoes just needed to be adjusted Makes sense as the I put in new shoes in the last 500km Quote Link to comment Share on other sites More sharing options...
