Radiator fan plug disconnect
Suprahitz
  • 2 weeks later...
I've just replaced my rad and this was a pain to get off, pinch the tab and tease it gentle off as you don't want to crack it. Old plugs are quite brittle.
In the end I used a thin flat blade screwdriver to lift the tab which 'clicks' and it came off.
Worst case, it's only two wires so you would replace both sides with a different mating plug.
