turbo choices
jay200bhp
Right gents ,just thinking aloud to be honest .. My engine at the moment has BC rods.Mahle pistons,arp throughout and runs a greddy exhaust manifold and wastegate.I have a divided turbo its a t4 flanged precision t6765.... If i were to change this for a smaller more responsive turbo... I.e a setup for savage savage acceleration... What size would you reccomend? Wouldnt be looking to change manifolds etc so bolt on would be good.Also my current t6765 has done less than 2000 miles and is perfect ehat sort of money do they fetch second hand?
Could also go down the route of the gen2 6466; still benefits from the new tech, fast spool and up to 900bhp. That's the one I'm looking at
Depends what power you want. People have done over 800rwhp on the 6266, but that will be race fuel and mega high boost.
Dean has a fair point, if I had a built engine I'd be running a 6466 now.
I'm not sure on prices, I got mine as part of a full Turbokit.
Jim is SupersizeJim on the forum.
I can confirm that I am very happy with my set up. I got a Gen 2 6266. Cant confirm on HP figures, but on my older and bigger turbo it made nearly 650hp. Other than the turbo change, all I have done is put a larger air filter on it, and a Titan crank pulley. Ryan G @bartunning has worked his magic on it, and it is now a lot more of a usable weapon. Boost is nice and early and seems to have a better, smoother and longer power band than the older bigger turbo that I had. Some of this may well be down to Ryan tho. Trying to get down to a rolling road after my car comes outta the bodyshop, just so I know a least what shes putting out anyways. :p
theres still alot of choices on that turbo its self what is best ? bearing config, turbine size ect ??
PTE's PT6266 Turbocharger features the following:
• Exclusive CEA (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging
• Higher efficiency and faster transient response for maximum power and performance
• 62mm inducer compressor wheel
• Compressor cover options:
- "E" compressor cover 3.0" inlet/2.0" outlet
- "S" compressor cover 4.0" inlet/2.5" outlet
- "Ported S" compressor cover 4.0" inlet/2.5" outlet
• Exclusive CEA (Competition Engineered Aerodynamics) 66mm, 76 trim turbine wheel
• Turbine housing options:
- T3 .63 or .82 A/R with 4 bolt (2.5") discharge
- T3 .63 A/R with 5 bolt discharge (with or without wastegate hole)
- T3 .63 or .82 A/R with 3" V-Band discharge
- V-Band inlet .82 A/R with V-Band discharge
- T4 Tangential .58, .68, .81, or .96 A/R with 3 5/8" V-Band discharge
- T4 Divided .84, 1.0, 1.15, or 1.32 A/R with 3 5/8" V-Band discharge
- Buick .63 or .85 A/R
- GMC Syclone/Typhoon .85 A/R
• Available with either a Hydrodynamic 360° thrust bearing system, or an Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
I'm on a ported S cover with a divided 1.00 ar.
6466 gen 2 will be around £1500 and that will be the one for me to replace my TO4Z
That's a big power turbo dude, you can't think of them as a 64mm turbo these days, that's a 900bhp turbo, that's more than the stock Pistons will handle I think.
Edited by JamieP (see edit history)
