Na to tt overdrive light flashing
The Raven
I had a similar issue though mine was an original TT and when I opened up the auto surround I found one of the cables had disconnected and all I had to do was reconnect.
Does it flash constantly as soon as you try the key or after a certainly time? Round corners etc?
Mine does the same. O/D light will flash at a steady pace although thats only whilst the O/D function is enabled. MANU mode is now non existant. Advice given to me was because of the TRAC Control not being there
Mine is different.
It flashes all the time, until turned on then it stays on
