Guest Big red johnson Posted November 5, 2014 Share Posted November 5, 2014 Hi all, I've got a auto tt running with a greddy profec 2, greddy emanage blue, induction kit, blitz bov (also have a has ssqv fitted as well) single cat with cat back exhaust. My problem is no matter what setting I have the profec set to the car over boosts to around 18psi (would go over but that's when I lift off). I've tried reducing all settings to minimum and nothing makes a difference, it reads the boost correctly (I have a separate apexi gauge for confirmation) and the warning alarm hoes off at 17.3psi, it just keeps boosting. I'm a fairly new to supras so any help would be greatly received. Link to comment Share on other sites More sharing options...
Tommyd16 Posted November 5, 2014 Share Posted November 5, 2014 Do you have a restrictor ring fitted in the exhaust? Link to comment Share on other sites More sharing options...
tony tt Posted November 5, 2014 Share Posted November 5, 2014 As above there should be a 1bar or 1.2bar restrictor ring fitted between the two de cat pipes. They are cheap anyway if it doesn't have one but that could be the issue. Link to comment Share on other sites More sharing options...
wile e coyote Posted November 5, 2014 Share Posted November 5, 2014 Boost controller correctly fitted ? First time I fitted one I fitted it incorrectly and over boosted Link to comment Share on other sites More sharing options...
Guest Big red johnson Posted November 5, 2014 Share Posted November 5, 2014 Tbh all the mods were done before I bought the car, I have no idea if a restrictor ring is there neither do I know if the boost controller is fitted correctly. I do have the new profec (oled display) ready to replace the profec 2 (not a fan of the old one) so I guess I could check when replacing it. Is it easy to see if a restrictor ring is there? Link to comment Share on other sites More sharing options...
Scott Posted November 5, 2014 Share Posted November 5, 2014 Have you tried turning the boost controller off altogether? Lack of restrictor ring is definitely the go-to solution but it could be an improperly fitted solenoid/boost controller causing the issues. Link to comment Share on other sites More sharing options...
Morzy2k5 Posted November 5, 2014 Share Posted November 5, 2014 Maybe it's set up/mapped to boost that high on the greddy emanage.i doubt it though as 18psi is fairly high on stock turbos. What injectors are you running.ideally need to know the full engine/mod spec to properly advise. But a restrictor ring would be the first port of call Link to comment Share on other sites More sharing options...
Guest Big red johnson Posted November 5, 2014 Share Posted November 5, 2014 Yep I've tried that, doesn't make a difference, occasionally I can hear the boost solenoid clicking away but not every time . Link to comment Share on other sites More sharing options...
Paul Whiffin Posted November 5, 2014 Share Posted November 5, 2014 Sounds like you need one of these http://www.garagewhifbitz.co.uk/garage-whifbitz-1068.html Link to comment Share on other sites More sharing options...
Guest Big red johnson Posted November 5, 2014 Share Posted November 5, 2014 I've wanted to get the car in for a tune up but there's no one around my area (Swindon) that have a rolling road or knowledge of the emanate blue, quite frustrating. Link to comment Share on other sites More sharing options...
Swampy442 Posted November 6, 2014 Share Posted November 6, 2014 Point of note, boost controllers cannot lower boost, only raise it above a set baseline. Link to comment Share on other sites More sharing options...
Littler Posted November 6, 2014 Share Posted November 6, 2014 Does you first post say you have a cat fitted? If that's the case a restrictor ring wouldn't be needed. That said I wouldn't be raising the boost through the controller or emanage with the cat there (albeit it could've been mapped to account for the cat) Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 6, 2014 Share Posted November 6, 2014 Pull the solenoid hoses off, and connect it back up in the stock fashion - ie put a piece of hose from the no.1 turbo back on to the actuator, thus removing the boost controller. Take it for a drive, and see what boost it reaches, should be circa 10psi iirc. If it's much higher than that, you could have a faulty actuator or wastegate Link to comment Share on other sites More sharing options...
