Guest Anger Posted November 5, 2014 Share Posted November 5, 2014 I have a tiptronic face lift TT with BPU and when I had it on track at Snetterton last month it misfired on the straights at about 115mph, anyone have any ideas what would cause this ? Thanks James Quote Link to comment Share on other sites More sharing options...
Geo Posted November 5, 2014 Share Posted November 5, 2014 plugs coil pack clips coil packs ignitor work your way through them Quote Link to comment Share on other sites More sharing options...
Guest Anger Posted November 5, 2014 Share Posted November 5, 2014 Thanks for the reply Would that be always at exactly the same speed Everytime with the parts you mentioned ? James Quote Link to comment Share on other sites More sharing options...
jcbt Posted November 5, 2014 Share Posted November 5, 2014 (edited) Thanks for the reply Would that be always at exactly the same speed Everytime with the parts you mentioned ? James Was it a misfire or did the engine come to a grinding halt like it had been starved of fuel. Also is it fine at other times when on full boost. If its a j-spec then it may have not been de-limited Edited November 5, 2014 by jcbt (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest lloydy Posted November 5, 2014 Share Posted November 5, 2014 yeh, could be the factory speed limiter, thats set at 112 mph, and isnt particularly pleasent when you hit it, i expect that could cause a misfire as its fuel cut limiter Quote Link to comment Share on other sites More sharing options...
Guest Anger Posted November 5, 2014 Share Posted November 5, 2014 (edited) It misfired and then went again to about 120mph where I was running out of track, I was wondering if where the limiter was taken off it was done properly And Yes it's a J spec Edited November 5, 2014 by Anger (see edit history) Quote Link to comment Share on other sites More sharing options...
