Samurai 20V Posted November 4, 2014 Share Posted November 4, 2014 Hi Guys.. Some sudden issues, my car was parked off for the last three weeks.. In that time, I started the car twice, no issues.. Fired it up today, slip control off light is flashing. Did a diagnostic, came up with error codes 32 and 42... I can locate a code 32 on the service manual, not a trace of a 42.. I checked the code twice.. Code 32 is Left front speed sensor.. What should I do? Change the speed sensor or just drive the car? The ABS system light is flashing normal when doing the diagnosis and off when car is idling.. Help! Thanks. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 5, 2014 Author Share Posted November 5, 2014 Anyone? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 5, 2014 Share Posted November 5, 2014 The ABS won't be working with a failed wheel speed sensor or sensor circuit. you may get a judder from the brake pedal on the first stop after a key off / on. But otherwise it'll drive as normal. I have driven Supras for hundreds of miles with similar issues. Test the ABS sensor before buying a new one. Depending on which side i have I may be able to supply a known good used one. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 5, 2014 Author Share Posted November 5, 2014 Thanks Chris.. Will drive the car a bit and see what happens.. The code shows a left front sensor.. Will keep you posted.. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 5, 2014 Share Posted November 5, 2014 If you have Racelogic Traction Control it has a means of seeing if that sensor is outputting OK. If not you need a `scope, or just change it and hope. Sadly the sensor I have is a right hand front. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 5, 2014 Author Share Posted November 5, 2014 If you have Racelogic Traction Control it has a means of seeing if that sensor is outputting OK. If not you need a `scope, or just change it and hope. Sadly the sensor I have is a right hand front. Stock Trac Chris.. Thanks for the offer anyway. Will drive the car and take it from there.. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 6, 2014 Author Share Posted November 6, 2014 Things are worse after the drive, picking up right front and left front sensor failure.. Also still got a code 42 which I can't find on the list.. The car is driving fine, no abs codes either.. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 6, 2014 Share Posted November 6, 2014 Isn't code 42 something to do with traction control? Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 6, 2014 Author Share Posted November 6, 2014 This is code 42 From the trac control system.. Not from the engine Ecu.. I suspect the trac Ecu is faulty. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 6, 2014 Share Posted November 6, 2014 Code 42 is the number one speed sensor (on the gearbox). It could be the sensor, the wiring or a gizmno like a top speed delimiter, or KMH to MPH converter playing up, too. If there are really 2 dead ABS wheel speed sensors the ABS system should, for sure, flag fault codes, and the ABS light should be on all the time. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 6, 2014 Author Share Posted November 6, 2014 Thanks Chris.. The Abs light is off.. (The light is working, lights up in startup and goes out after 3 seconds). There are no abs codes. I don't have a speed delimiter device fitted. My next course of action is to swap the trac ecu for a known working one, hope that's logical.. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 6, 2014 Share Posted November 6, 2014 No, I would remove any speedo converter or top speed delimiter, anything none stock connected to that area of control. Return the wiring to standard. Check if there are any gizmos alongside the transmission, early imports tended to have them fitted underneath the car. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 6, 2014 Author Share Posted November 6, 2014 No, I would remove any speedo converter or top speed delimiter, anything none stock connected to that area of control. Return the wiring to standard. Check if there are any gizmos alongside the transmission, early imports tended to have them fitted underneath the car. No Speed delimiter near the ecu or gizmos under the car, I have checked previously. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 6, 2014 Author Share Posted November 6, 2014 Just cleared the codes.. The wheel sensors codes have disappeared... Moved the car front and back a few times, they did not reappear. The code 42 is still there. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 6, 2014 Share Posted November 6, 2014 Does the speedo read in MPH on the standard KPH dial? Will it go well over 115 MPH? Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 6, 2014 Author Share Posted November 6, 2014 It reads in km/h... It does not go over 180km/h ( 112mph) Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 9, 2014 Author Share Posted November 9, 2014 Swapped the Trac ECU with a working one from a friends car... Problem solved.. Light operation normal.. Now have to find a used one that works.. Or just remove it.. Quote Link to comment Share on other sites More sharing options...
np89 Posted November 14, 2014 Share Posted November 14, 2014 Just pull the trac fuse out Quote Link to comment Share on other sites More sharing options...
