SupraLEDrears Posted November 4, 2014 Share Posted November 4, 2014 So I'm just sorting out things one at a time. I've noticed that my AC pulley makes a grinding noise like metal on metal. It does it whether the AC is on or off. If I spray som WD40 into the centre it stops for a few hours. How do I get rid of this? Thanks(AC is working fine) 93 NA manual Quote Link to comment Share on other sites More sharing options...
Fitz Posted November 4, 2014 Share Posted November 4, 2014 Knackered Aux Bearing? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 5, 2014 Share Posted November 5, 2014 Hi, thanks for that ECU As the pulley is locked to the compressor waddle plate when the A/C is on (assuming it has enough gas in it to operate the low gas pressure switch), the big bearing inside the pulley will not then be turning. With the A/C off, or not enough gas charge for the safety switch to allow the A/C electromagnetic clutch to engage, the pulley spins supposedly freely on the bearing within it. Therefore if the A/C pump is actually being engaged, and the the noiuse is still there, it can't be the bearing making it. If the noise is there with the A/c off and the clutch disengaged, it can't be the compressor itself. Belt noise? Some brands can make a lot of odd noises, spray the *belt* with water or WD40, does the noise stop? It may be you are getting WD40 on the *belt* when you spray the pulley. Is it there if you run the engine for less than a couple of minutes with the belt off altogether? Listen *CAREFULLY, so you don't entangle it in anything moving, and poke it through your head....), with a screwdriver against your ear, touching things, you should be able to find the source like that. It is NOT a health and safety approved method though!! Quote Link to comment Share on other sites More sharing options...
