The Guv’nor Build
Supraleeturbo
Where did you source a V160 shifter if you don't mind? I have the V161 and would love to reduce the throw but don't want to install a short shifter
I've had it quite a while in a spares box, unfortunately the V160 it belonged to was stolen a couple of years ago now
Has anyone on here using a rps carbon carbon triple plate clutch and if so how there getting on with it
I'm using one mate, works pretty much like a stocker. Bit sharper in the low gears but down to practice in my opinion. Pedal feel is like stock, nice and smooth, very little rattle out of it ever.
That's good to here plus apparently after speaking to Leep and stevem say you can abuse it as much as you like witch suites me fine
  • 3 months later...
So bit of an update, I thought i was having to sell my car due to moving out and having a little nipper on the way but ive managed to keep her and carry on with the build,i wont be taking it as far as i would like to but i will get to that point at a later date, here's my new list of whats going on with the build
Engine:
Srd stage 1 head with srd Billet 264 cams and valve springs (check)
Hks type 2 cam pullys/Titan motorsports cam pulleys
Arp H11 head stud kit
Arp main studs
polished top water neck (check)
Polished cam covers (check)
Polished turbo housing
New coil packs (check)
New cam belt
New Oem aux belt
New oem tensioner
New oem engine gasket seal set (check)
New oem water pump (check)
New oem block caps
New oem oil pump (check)
New Srd alternater
New facelift sump pan (check)
New fluid damper crank pulley
Fully balanced, Re Honed and decked block
All new clevit bearings
Mahle pistons 86.5m
BC Pro Rods 625+
Srd brace kit (Main caps)
32,000km v161 (check)
Brand New V161 Shifter (check)
SRD Heavy Duty Prop
Re freshed BO3B diff and shafts (check)
K Sport 8 pot with 356mm discs
  • 1 month later...
  • 1 year later...
So after what seems a life time the car well engine is now up srd being built, after having a crap year with loosing a baby and having to pay a stupid amount of rent and bills and a car smash (in my van) the build was put on hold, but now Lee and the boys will do what they do best and hoping to get the car back for when the nice weather comes, will update this thread with the build as and when I get updates for srd, but I’m hoping to get out to most of the meets and shows and dB and Jake aka ripped fears uk trip
Engine:
BC springs and titanium retainers
Arp main studs
ARP rod bolts
Full srd fuel system
Aeromotive fuel filter
New coil packs
New cam belt
New Oem aux belt
New oem tensioner
New oem idler wheel
New oem water pump
New oem block caps
New oem oil pump
New Srd alternater
Stock pistons and rods with brand new rings
Crank polished and balanced
32,000km v161
New rsp street max clutch
Edited by Supraleeturbo (see edit history)
